588,653 active members*
7,081 visitors online*
Page 1 of 3 123
Results 1 to 20 of 47
    Jan 2007
    131
    What will I make Is the popular question...
    After reading many posts and spending lots of hours on CNCZone and other sites I've started my first CNC machine.
    My friends all think I'm nuts but my girlfriend is so far supportive as she will get come finely cut craft wood.. (assuming that I am successful). I'm just a builder and currently the machine is my goal...
    Aug 2004
    3215
    What size Machine are you planning?
    Jan 2007
    131
    Re: What Size
    Quote Originally Posted by joe2000che View Post
    My Z-axiz came out 6 inches wide... I was hoping for maybe a 20" travel on the gantry (x-axis I think) and maybe 30" on the bed for the gantry to travel..
    Jan 2007
    131
    The Z-Axis had alot of re-manufactured parts..
    Well, I pretty much designed and fooled around with a small z-axis, Building from the top down... I've learned a few lessons about using a router to cut the plastic (Including sending a peice sailing across the garage)...
    Here is near the finished peice... I'm now working on the gantry section and
    mounts for the z-Axiz...
    Currently I'm using a section of 1/4 threaded rod with a tapped block of
    nylon for the nut. I'm not sure how this will hold up. For the remaining screws I'm switching to the popular 1/2-10 Acme screws..
    Aug 2004
    3215
    Quote Originally Posted by milhead View Post
    you may want to use some tubing or some way to lock the possition of the bearing so it does not slide along the u-bolt to the sides, here is what i did om my cnc Model 2006.
    Jan 2007
    131
    Thanks for the suggestion Joe, I will add the tubes when I take it apart to paint it (I've decided on purple as it's my girlfriends favorite color and I'm going to need all the compassion I can get, she is just realizing the time I'll be putting into this)...
    Aug 2004
    3215
    as soon as you get the machine finished cut her portrait and stick it to the side of the machine, and tell her that way you can be thinking of her while using the machine... LOL
    Jan 2007
    131
    Red face Beginnings of a gantry...
    Tonight (while hiding from the snow.. near portland).. I got the basics of the Gantry put together...
    Looks like the finished product will allow a width of about 18 inches... I've not worked out the length.
    Here is a question for all the CNC fans out there.. Which axis typically is represented by the carriage sliding on the gantry... Y or X?
    I also need to get to work on the electronics, but am eager to complete the mechanism first.. I'm not too worried about the electronics part.
    Miller
    35538
    The Z axis moves along the Y axis, the gantry moves along the X axis.
    Aug 2004
    3215
    Miller
    Generally most people use the gantry for Z and Y because the bed is the longest x axis, Look at it as if you were standing on the left side looking at the machine and reading a set of plans.
    Aug 2003
    454
    Generally, though not always, the longest, horizontal axis is X, the shorter of the two horizontal axes is Y and the vertical axis is Z.
    Mike
    Jul 2005
    668
    My X and Z are on the gantry. I think the only real convention is that the Z axis is up/down.
    Steve
    DO SOMETHING, EVEN IF IT'S WRONG!
    Jan 2007
    131
    Smile What's a few more hours...
    Well I was able to spend several hours on the Gantry mechanism over the weekend.. It looks like I'll have about a 20" x 30" travel for y, x respectivly,
    Give or take an inch...
    I have learned the desire to have a machine in order to spit out parts for a
    second machine, I think all of the error that is introduced in this mechanism
    so far has been done so by me and my router...
    As a result I took a 2 hour side bar and slapped together a router table
    out of the MDF, I'm using my old Craftsman workhorse as a base.. This
    Thing is a real time and error saver, I think I've only taken the router out
    of the table once since I built it.... So now I'm kicking myself for not
    building one years ago..
    I've always looked at them in the store and thought it would be useful... Well it cost a whopping $4.00 to build... (*add a few screws,
    some glue, a few biscuits, and two C-clamps to hold the fence in place..)
    On a sad note, Cutting off some bolts caused my Dremel to die. The one
    I've had since high school (20+ years I think)..
    What's your opinion, Do I add the cost of a new fangled Dremel tool to
    my running total that I attribute to the machine? Or are tools overhead
    that get accounted with rent, lights and Kerosene (to make the garage
    not freeze).
    Jan 2007
    131
    About the base...
    The photos above show a peice of 1/8 MDF on top of the base, this is NOT what I'm planning to use here... I'll have a 24x36 3/4 MDF top for the
    table with two largish peices of angle iron running the length to keep it flat.
    I'm not sure how to measure a torsional defection of the table yet but I'm
    sure that I'm going to have a problem with it. I'm content for now to allow
    the table to have some torsional flex but be rigid enough that I can adjust
    it out when I set it on a hard flat surface...
    A torsion box of some sort will probably be a result of my next round. I like
    Joe's as it accounts for both torsional flex in the base as well as loading
    flex on the large X axis rails.
    Having a machine that can cut the ribs sounds like good fun...
    Mil
    Jan 2007
    131
    wire management....
    Has anyone come up with a good cheep way to guide wire
    for cheep?
    After poking around the commercial sites for a while I think I'm going
    to try using a section of Stanley Fat-Max tape measure with my 10
    z-axis wires and 20 gantry wires.. Either I'll tape the wires on at intervals
    (cheep links) or use some sort of loosely braided string...
    I think the concern is that if the wires get around the edge of steel
    tape it will be a short time before it cuts through the insulation...
    I'll see if home sells replacement tapes, I hate to hack up a good one..
    Miller
    Oct 2005
    1238
    Exclamation Wire Insulation Protection
    To protect the wire insulation you might run the wires through some "split plastic loom" that is taped to the Fat-Max blade.
    Oct 2004
    590
    Mil
    Nice looking machine. The Purple Z is great. You might want to think about adding a stiffening rib to each of the gantry sides spanning from the x-axis rails up into the region where the gantry back attaches to the sides. Something like a 1x2 in a local hard wood or even an aluminum angle screwed and glued in place. In cross-section parallel to the x-y plane the sides should look like stubby Tees.
    Chris
    Jan 2007
    131
    I played with it some during lunch, The loop that the tape will make is approx the diameter that the tape has... I think my first attempt will be to tape at about 2-3" intervals some trailer wire...
    I'm not sure if it will work, The wire has to compress around the bend or create a slack bulge. All of the commercial chains hinge in the middle of the cavity for this reason...
    May 2005
    405
    Lots of ideas around cable carriers here.
    http://www.cnczone.com/forums/showthread.php?t=25257
    Paul
    Jan 2007
    131
    Several hours and More Progress
    Well, I deviated from the all wood system for the base, I took some scrap
    iron from the nasty garage and a rented Home Depot welder and welded a
    square to hold the two end peices and to support the table.
    Aside from converting four spots of my MDF jig into char with appropriate
    flames the resulting frame came out very true (Or at least as much as I
    can tell with my good carpenters square).. The folks in the other apartments probably dont see alot of welding in the mini garages here...
    Oh well.
    I put the base and the gantry drive together.. There is a tad of rack
    possible but I have to tweak pretty hard to get a barely noticable movement..
    I know that any visible movement will spin the dial on my caliper.. But for
    my first attempt an any of this apparatus I'm pretty stoked.
    I now have the motors and drives attached for all three axis..
    My last box from All Electronics also came this week so I thinking of
    starting the electronics but am still having fun building so I worked a
    bit to template, rough cut and route out the palstic for the cutter mounts.
    I need only now to reassemble the Z axis and the basic mechanism will be
    complete.
    I've got a long list of honey-do's so my Saturday may be CNC-Free
    But the electronics, limiit-switches, e-stop and motors will soon be
    assembled...
Page 1 of 3 123
