587,197 active members*
2,780 visitors online*
Results 1 to 18 of 18
    Feb 2005
    149
    Dual purpose CNC
    I have been using my CNC 3 Axis Router successfully for several years, but now I want to experiment.
    I currently run Mach3 with Aspire software and now want to try Laser engraving.
    I do not want to build a complete new machine as I have one which is perfectly adequate.
    I want to go gently gently and start off by replacing my spindle motor with a 15W 450nm laser head of the type shown.
    Question are
    • Is there a freebie software to control my 3 axis system, recommendations please!
    • Will the laser head I have chosen be able to cut 5mm plywood? If not what are my options ?
    • How is focus achieved
    • How is depth of cut achieved
    Hopefuly someone can help.
    George
    ericks Guest
    Re: Dual purpose CNC
    Hi, i was also looking into this a while back. Ended up looking at "endurance lasers". They seem to have these low wattage units properly designed and cooled. All the best with your project, i will be following this
    Feb 2005
    149
    Hi Eriks,
    Whats an Endurance laser ??
    ericks Guest
    Quote Originally Posted by George View Post
    Hi Eriks,
    I was just looking at the laser you showed in the pic....endurance lasers make something similar but with the higher wattage (10W) units in these type of lasers they use heatsinks with peltier cooling.
    Feb 2005
    149
    Quote Originally Posted by ericks View Post
    Thanks eriks, So it's similar. The one I have shown is 15Watt. Will the 10W version cut through 5mm Plywood. Do you have a manufacturers model or part number on your laser, where can I buy ?
    ericks Guest
    I did not buy one, was just doing a bit of research. The strongest they do is 10W. Best to visit their site, if you contact them they are very good at answering questions
    endurancelasers.com
    Apr 2005
    304
    Arduino Nano/Uno loaded with GRBL 1.1f as a controller and bCNC or UGS (Universal Gcode Sender od LaserGRBL
    On my machine I use Mach3 when a spindle is on machine and LaserGRBL when my 2.5W laser is on.
    Works like charm. GRBL has adaptive power controll of a PWM for laser during acceleration/deceleration.
    HTH
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
    Feb 2005
    149
    Quote Originally Posted by ZASto View Post
    HTH
    I Ideally I wanted to use my existing control board, the electronics are already in place driving the steppers so why go and add an Arduino ?? Does your 2.5watt laser cut 5mm plywood ?
    Thanks for you reply.
    George
    1943
    George
    If you are running through a parallel port breakout board you can simply connect the wires from a, old parallel port cable to the Arduino without the need to change anything.
    Feb 2005
    149
    Thanks, I'm using a C11 multifunction board from CNC4pc.com which utilizes the parallel port, I would like some more info on adding the Arduino and software control.
    Feb 2005
    149
    HTH
    So you are using your original 3 axis stepper? Do you have any build details for the Arduino? Connection diagram ec?
    How is Focus achieved?
    Is the Z axis utelised to control depth of cut?
    Lots more questions to come no doubt.
    I was looking at using the laser head show in my earlier post, can that be used with the Arduino ?
    How about cutting thin plywood say 3 to 5mm thick > can it be done.
    Can you recommend a laser head ?
    35538
    Maybe, with a lot of passes? A diode laser is going to be marginal at cutting even 3mm wood.
    Feb 2005
    149
    Aha! learning starts, so what I proposed to use is a diode laser ??
    What alternatives is there to enable me to engrave or cut 5mm Ply ??
    1943
    Here is an old post from years ago where I show how I connected an Arduino running Grbl to a parallel port BOB. You would have to do the same but use the pinout from your board and what each pp pin does to figure out where to wire it on the Arduino.
    https://www.cnczone.com/forums/gener...-software.html
    To learn more about Grbl go here: https://github.com/gnea/grbl/wiki
    For a laser I think this is the most advanced interface: https://github.com/arkypita/LaserGRBL/wiki and LaserGRBL – Free Laser Engraving
    35538
    Apr 2005
    304
    If you want to use Arduino Nano, here are the files so that you can make an adapter board.
    The D-25 is feemale, as on your computer.
    Pinout is the same as for Mach3, Pin 1 is PWM!!
    All home/limit switches are NC.
    Attachment 422208
    GRBL-LPT-B_Cu.pdf
    1943
    Attachment 422208
    GRBL-LPT-B_Cu.pdf
    You will need to verify that the pinout of this board is correct for the breakout board you are currently using. As far as "Being the same as Mach3", Mach 3 has software customizable pinouts so that cannot be guaranteed.
    Apr 2005
    304
    Welll...
    I do use Mach3 and GRBL with a board that iI attached pic and pdf.
    I just switch LPT cable from computer to my adapter board.
    On the other end is 5 axis breakout board (of course, chineese made)
    OK, maybe I cheateed a little bit, I recompiled GRBL with a bit different pinout to be compatible with my BOB pinout.
    Anyway, dynamic laser power works like a charm, no overburn at edges.
    BTW the USB connector is for powering BOB (needs 5V.
  1. Replies: 0
    Last Post: 07-02-2016, 10:28 PM
  2. 4'x9' Dual purpose router build
    By sfrankland in forum CNC Wood Router Project Log
    Last Post: 01-06-2011, 03:26 AM
  3. Dual Steppers or Timing Belt for Dual X-axis?
    By GEBrown in forum Linear and Rotary Motion
    Last Post: 05-27-2010, 05:45 PM
  4. dual purpose cnc router
    By junkmail in forum DIY CNC Router Table Machines
    Last Post: 03-10-2004, 07:01 PM
