587,255 active members*
3,192 visitors online*
IndustryArena Forum > CAM Software > Mastercam > switching x and y
Results 1 to 5 of 5
    Jul 2005
    969
    switching x and y
    i cant remember where to go to switch my axis, the reason been that i have selected a new wcs to work with but i like to have zxy instead of zyx in the corner that i have selected but i cant seem to remember were i saw that option in mcx (x3)
    The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne
    Mar 2005
    461
    Sounds like the new wcs you created is wrong.
    I think there may be a way to adjust it but honestly I'd be more likely to create it again (correctly this time) and then just delete the bad one.
    If you're having trouble getting it oriented the way you want, use the 2 line method. Create a line starting at your desired origin in the direction that you want X+ to be. Do the same for the Y+.... Then create a WCS by "geometry" selecting the 2 lines (always grab X first) and your wcs comes out perfectly oriented every time.
    You'd probably really like the Dynamic WCS feature in X4. It simplifies this process a bit.
    Aug 2008
    64
    Unless you are using X4 you can't adjust your axes. Do what Matt said using the two line method. I use it all the time, and it works great!
    Jul 2005
    969
    yeah that is waht i tryed it seems to work ok but.... but with this method the z axis seems to point in different direction depending on the place you put your xy so sometime it will point down and sometime it will point up but anyway ill try to manage it this way i heard alot of good from x4 but i also so heard that it had its fare share of bug
    Mar 2005
    461
    Quote Originally Posted by ataxy View Post
    If you always create the lines pointing in the X+ direction and the Y+ direction your Z+ will be correct the first time every time. But if you mess up with the lines creation you can still toggle through the available choices before you accept the WCS you created.
  1. switching between 2 controllers ????
    By jubee in forum CNC Machine Related Electronics
    Last Post: 02-27-2008, 08:49 PM
  2. Switching from one computer to another.
    By Wahoo4 in forum BobCad-Cam
    Last Post: 12-27-2007, 03:32 AM
  3. Need a little help switching from a Fanuc 6t to a 18t
    By dmcool in forum G-Code Programing
    Last Post: 06-08-2007, 06:32 PM
  4. Pwm switching
    By miro in forum Gecko Drives
    Last Post: 01-23-2007, 10:22 PM
  5. Switching to carbide?
    By warpedmephisto in forum Benchtop Machines
    Last Post: 06-23-2006, 10:46 PM
