587,221 active members*
2,973 visitors online*
IndustryArena Forum > CNC Electronics > Rutex Products > Servo Drives > Bridgeport DX-32 (Explorer I) / Conversion
Results 1 to 3 of 3
    Nov 2008
    3
    Hello, my name is Alejandro I'm new in the group. I need retorfit an Bridgeport Explorer I.
    The servomotors are: SEM MT30M4-28, 4000RPM, 26lb/in, 112V 65A,
    they work with analog servo-amplifier at 100VDC of DC BUS.
    I have two way:
    1- adapt analog amplifier to digital interface STEP/DIR with Skyko. (the problem is skyko are discontinued product and I don't know/find similar product).
    or
    2- put new drives (the problem is the voltage of opeartion 100VDC, all of drives work maximum 80VDC).
    Please send me yours commentaries...
    Thanks in advanced, regards
    Alejandro Gonzalez
    Feb 2007
    966
    The Viper 200 drive will drive those motors fine. Others have done the retrofit on the same machine.
    Dec 2005
    3319
    WHy retrofit? Problems with DX32?
    What are you doing with old DX32 stuff?
  1. need help on my bridgeport conversion
    By pham1129 in forum Knee Vertical Mills
    Last Post: 07-08-2008, 05:24 AM
  2. BridgePort Explorer X-26 Gear Range Issue
    By Lesleh in forum Bridgeport / Hardinge Mills
    Last Post: 12-01-2005, 02:27 AM
  3. Bridgeport cnc conversion?
    By Bryscnc in forum Bridgeport / Hardinge Mills
    Last Post: 03-11-2005, 02:07 AM
  4. Bridgeport Explorer CNCs
    By arsenix in forum Bridgeport / Hardinge Mills
    Last Post: 02-11-2005, 01:28 AM
