588,460 active members*
5,445 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Is it just me or HAAS machines don't mill (feed) as fast as it claims?
Results 1 to 11 of 11
    Jan 2016
    33
    https://www.youtube.com/watch?v=yL4Z232P-ew
    I was watching this video on youtube & no way in hell it is going 2,200IPM.
    I see this in many HAAS videos, maybe HAAS machines have an internal limiter? Or maybe the acceleration of the stepper motors are limiting it?
    Thoughts??
    Same with these guys
    https://www.youtube.com/watch?v=2fuYj4trEGg
    Nov 2012
    1278
    Re: Is it just me or HAAS machines don't mill (feed) as fast as it claims?
    There is not a whole lot of long rapids in these videos, but the Y and Z moves in the very beginning of the first video (0:06 time mark) are pretty damn fast. Also, are you perchance confusing rapid feed rate and cutting feed rate? If the machine is capable of 2200ipm rapid moves, that does not mean the actual cutting could or should be done at that speed.
    Oct 2010
    171
    Many high end machine manufacturers apply a rapid rating in "Gs" of acceleration, which is actually a much more relevant number than IPM since that takes *distance* into consideration.
    No machine is going to hit 2000+IPM rapid in a short distance, regardless of its ultimate capability.
    PM
    15362
    danaman
    It would pay to get a better understanding on machines in general, machines like this do no use Stepper motors, these machines use high speed AC servos with 20 Bit Encoders,
    You are confused with the machine Rapid feed which is 2,200IPM this is not the cut feed that they are using, they don't say what the feed rate is, there are machines that run much faster than this, with Rapid moves of 3,500 / 5,000IPM Plus, is normal for a 4g Linear motor machine
    In the first Haas Video they where cutting a steel part, so it was moving at a fast speed for cutting steel, ( more than 200IPM ) there where lots of tool changes all running at different speeds / feed rates being used, including rigid tapping in this demo
    The speed any machine can run at is a combination of many things, Ballscrew Pitch, axes motor RPM Spindle RPM, and how rigid the machine is, the control also has to be able to process the program, to move the machine and hold accuracy
    Here is a Linear motor machine
    https://www.bing.com/videos/search?q...6BC3&FORM=VIRE
    Mactec54
    Nov 2012
    1278
    BTW, in the second video you can see a glimpse of the computer screen showing the feed rate of 800 (presumably inches per minute).
    Mar 2014
    133
    Feeding at 2,200 Ipm is insane. Rapid movements at 2,200 ipm is for high speed production. Faster tool changes,faster rapids to get your tools down to the part faster before you start feeding into a cut within the tooling limits.
    Jul 2014
    51
    It's like gas mileage claims, all bull.
    15362
    Quote Originally Posted by hoecken View Post
    Another person that can't read, the first video is correct, they did not clam that it was doing 2,200IPM cutting, the second one is not unusual either to be running at that speed milling aluminum, if you want to compete you have to run at these speeds, or you are left behind with no work, and out of business
    Mactec54
    Jul 2014
    51
    mactec54:
    You have no sense of humor.
    15362
    mactec54:
    There was nothing humorous, about what you said ( It's like gas mileage claims, all bull. ) it's saying the Haas Video is all Bull, and it is not
    Mactec54
    Nov 2010
    73
    HIGH SPEED MACHINING (REALLY HIGH!!!)
    This is not a HAAS machine, but it's very fast
    https://www.youtube.com/watch?v=E3AqIZURMbI
  1. BobCAD Post Processor for HAAS Mill Turn Machines
    By aldepoalo in forum Haas Lathes
    Last Post: 06-07-2016, 04:03 PM
  2. Machine Shop claims they can't mill my part, hardened steel mold die, help!
    By DREXENG2015 in forum Hard / High Speed Machining
    Last Post: 10-03-2014, 10:22 PM
  3. Replies: 0
    Last Post: 01-23-2014, 08:54 PM
  4. Silly Question BUT What Unit is Feed in on a Haas Mill
    By JWB_Machining in forum Haas Mills
    Last Post: 10-15-2008, 01:39 PM
