587,936 active members*
5,324 visitors online*
IndustryArena Forum > MetalWorking Machines > Knee Vertical Mills > HELP Enshu Yuasa AccuMill 1547 with Fanuc 3M
Results 1 to 2 of 2
    I have an Enshu Yuasa AccuMill 1547 with Fanuc 3M. It has worked well for years. The last time I powered it up, I got a not ready message on the controller. I was able to get the machine to move in all axis by holding the limit release switch but only in the - direction. I am not hearing the normal sounds I hear on start up.
    There are no blown fuses, no apparent relay issues, or anything that jumps out saying this is the problem.
    Please help if you can.
    Ed
    Aug 2020
    14
    Re: HELP Enshu Yuasa AccuMill 1547 with Fanuc 3M
    Quote Originally Posted by EDL at AU View Post
    Ed
    Interesting. If anyone can help me with a similar problem, described here, please do.
    https://www.cnczone.com/forums/fanuc...tem-ready.html
  1. NEED ADVICE re: Enshu Yuasa AccuMill 1547 with Fanuc 3M
    By crobox in forum Knee Vertical Mills
    Last Post: 01-20-2023, 10:00 PM
  2. Enclosure for a Enshu AccuMill
    By AccuMillGuy in forum Knee Vertical Mills
    Last Post: 08-28-2020, 12:47 PM
  3. enshu yuasa accu-mill am1547 tool offsets?
    By kustomkb in forum Uncategorised MetalWorking Machines
    Last Post: 08-28-2020, 12:44 PM
  4. Enshu Yuasa AccuMill 1547 with Fanuc 3M
    By fixer2 in forum Knee Vertical Mills
    Last Post: 08-28-2020, 12:37 PM
  5. Troubles with YUASA ACCU-MILL AM 1547
    By thucmie in forum Uncategorised MetalWorking Machines
    Last Post: 09-09-2008, 08:37 AM
