587,996 active members*
4,750 visitors online*
Results 1 to 11 of 11
    Jan 2015
    14
    Fanuc 0M-C enable macro B issue
    Hi All,
    I have been working on enabling macro B on my Fanuc 0M-C but it seems like it does not "stick".
    (param 912 Macro A is also 0x00)
    My sequence is as follows:
    machine on -> pwe 1 -> estop -> parameter 913 set to 10000000 -> input -> get p/s 000 error. I was in mdi mode when trying to edit it. Write protect key (allow write).
    Have tried a re-start and re-boot (as that is what error 000 means) but that does not seem to help.
    Al_The_Man Seems to remember the following:
    "... many of my notes are no longer around, there is a parameter to set to allow it to be enabled which I cannot find at the moment. will keep on looking."
    Perhaps somebody else seems to remember it?
    Dec 2015
    174
    Re: Fanuc 0M-C enable macro B issue
    902-01000000
    917-00010000
    912-10000000
    Apr 2009
    1381
    p/s 000 alarm means that the control power has to be cycled.
    Jan 2015
    14
    Yeah i did that. but it does not "stick" . I tried just turning it on and off with the putton on the frontpanel and by rebooting the system by means of the mains switch.
    Parameter 913 stays at 0x00; i will try to do the parameters that phucrobusl sent. Perhaps it is missing another parameter to allow 913. I'm not sure.
    Apr 2009
    1381
    Are you leaving the other bits (x) unchanged?
    902-x1xxxxxx macro A
    917-xxx1xxxx macro variables 600
    912-1xxxxxxx macro executer
    913-1xxxxxxx macro B
    Jan 2015
    14
    Quote Originally Posted by memoryman View Post
    So far i have only changed 913. But i will try the above parameters. I will leave the x unchanged.
    Jan 2015
    14
    I just checked my backup and current settings is this:
    902-x1xxxxxx macro A = 01000000
    917-xxx1xxxx macro variables 600 = 00000000
    912-1xxxxxxx macro executer = 00000000
    913-1xxxxxxx macro B = 00000000
    Jan 2015
    14
    So I tried it on the machine and 902, 912 i'm able to change. However when i do 917 or 913 it does not stick.
    I made a video to show it happening:
    Any ideas?
    Apr 2009
    1381
    What is your software? You may not have the eproms for the macro B option.
    Jan 2015
    14
    When i start the machine the following is on the screen:
    0453 - 03
    PMC 5B03-01
    How can i check the software version?
    Apr 2009
    1381
    0453 - 03 is the software. My option list shows that 0453 does not support macro B.
  1. GR200E coolant enable issue
    By GI1983 in forum Philips
    Last Post: 08-09-2022, 12:27 PM
  2. Enable Macro A or B on Fanuc 6T?
    By mflux_gamblej in forum Mori Seiki lathes
    Last Post: 08-24-2018, 08:16 PM
  3. Doosan Fanuc 31i G65 Macro to G code cycle issue
    By gavintwopies in forum Daewoo/Doosan
    Last Post: 03-07-2018, 11:43 PM
  4. Enable Macro Executer Power Mate D
    By ErikHdez in forum Fanuc
    Last Post: 03-14-2017, 05:07 AM
  5. Enable Macro
    By tc26 in forum Haas Mills
    Last Post: 04-23-2012, 04:43 PM
