588,277 active members*
4,928 visitors online*
    Feb 2006
    338
    Question Mazak spindle orient to angle
    This is specifically for an HCN6000 II mill. For doing things like broaching. I havn't found any mention of options for this, but if you know of one I'll look into that as well.
    Anyone use a macro program to orient the spindle to specific angles? Specifically it looks like setting SA96 then commanding M19 would work. I have a similar macro for fanuc that works this way I might try to modify if no one has any proven solutions.
    Dec 2012
    5
    Re: Mazak spindle orient to angle
    SA96 will change the spindle orient position for tool changing which will not be good
    Can you set your broaching tool so it is in the correct position when M19 is commanded ?
    Quote Originally Posted by dpuch View Post
    Feb 2006
    338
    Well one application is an male internal key that requires multiple rotations. So not really.
    When you say it isn't good to change SA96, apart from not restoring the correct value before a tool change are there any other issues your aware of? I have a fanuc variant that works well that also works by changing the orient value. It has the original value hard coded into the macro to always reset the value if an angle is not commanded.
    I'm really just looking for a proven macro, or at least making sure this hasn't been tried and a real problem found.
    Quote Originally Posted by Rustynut145 View Post
    Dec 2012
    5
    Yes, if you can change SA96 back before a tool change it should be OK
    I had a look in the manual, I can't see a system variable listed for SA96
  1. MAZAK VTC-16 Alarms- 280 (tool clamp impossible) 284 (spindle orient impossible)
    By Multi-DNC_user in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-12-2023, 02:47 PM
  2. Mazak AJV32 Spindle orient alarm 242
    By senna95 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-14-2013, 10:35 AM
  3. 2nd spindle orient
    By 1234567 in forum Mori Seiki Mills
    Last Post: 08-29-2012, 05:53 PM
  4. Spindle Orient
    By molassesbros in forum OKK
    Last Post: 09-11-2010, 10:35 AM
  5. M19 Spindle Orient
    By ragman in forum Fanuc
    Last Post: 04-01-2008, 11:16 AM
