587,865 active members*
3,336 visitors online*
IndustryArena Forum > Mechanical Engineering > T-Slot CNC building > Single axis electrical discharge machine ( EDM )
Results 1 to 7 of 7
    Mar 2018
    71
    After building this big CNC router in the past I decided to move on.
    https://www.cnczone.com/forums/diy-c...inium-cnc.html
    And that's how this bad boy came to life:
    It is a highly customizable single axis, "mostly 3D printed" sinker EDM with a custom software and touchscreen.
    It has many options to fine tune the process.
    It currently runs on a single ESP32 but this may change to a quad-core NanoPi Neo to support 4 axis later. Also a wire EDM module will be added after the final design for the X and Y xis is done.
    The final control panel will look different from what is shown in the video. The PSU for the steppers will be included in the 19" rack later.
    Mar 2018
    71
    Re: Single axis electrical discharge machine ( EDM )
    The project is now on kickstarter if anyone is interested:
    https://www.kickstarter.com/projects...charge-machine
    Mar 2018
    71
    Just a small update.
    X and Y axis design:
    The new toolhead with a HGR15 rail dual ball bearings for the spindle and a belt tensioner:
    The new control panel:
    Small video time lapse of wiring the new control panel:
    Mar 2018
    71
    A lot of time has passed and a lot of things have change. The single axis sinker EDM is now a fully 3 axis EDM CNC that can do sinker EDM, EDM engraving, Drilling and also Wire EDM.
    Cutting HSS steel with a 0.2mm wire:
    Mar 2018
    71
    Mar 2018
    71
    Mar 2018
    71
    So much has changed. New software, new sensing, new Controlpanel and also the mechanics itself has changed.
    Meet The G-EDM EVO2:
  1. Replies: 1
    Last Post: 10-04-2022, 06:08 PM
  2. EDM Wire Cutting Machine Electrical Discharge Machining
    By automationtechinc in forum Automation Technology Products
    Last Post: 07-22-2021, 04:40 PM
  3. Sink Electrical Discharge Machining
    By diarmaid in forum MetalWork Discussion
    Last Post: 07-27-2007, 08:20 PM
