I need the software of the operating system for this machine and any document available for it.
Thanx
Thanx
You are asking for a almost imposible thing. If the OEM will not provide it no one else will. They use there own software. It's hard to get any help on Italian machines. But don't give up trying.
Dennis
Hi
I was working on this machine and I know a lot about it
i am sort of new to cnc stuff had a little dabble 10 years ago
and thought this stuff is boring id rather cut glass by hand
now i am on it again but want to learn as much as i can
i would like to know a few things right now
about bavelloni alpa 315 if you know
mainly some MDI things
like how to pick a tool and things like that
daniel d
Hı please concactme [email protected]
also I can help to produce post processing for that machine just send me any old file
Yes I can get you a compatible version of easycad/cam for the generation of your NUM controller, send me your email address and I'll zip it to you.
Kendon.
Please send if you can at [email protected]
hello kendon thank you for your help please send me your compatible version of easycad/cam our email is [email protected] thank you a lot
we have alpa 320/4
hello, thank you for your help; please send me your compatible version of easycad/cam our email is [email protected]
thank you a lot
we have Kam 320/4
anyone got the easycad cam running under a Win7/vista system ??
Send download link [email protected]
hiii
can i also the link for downloading easycad?
& does the easycad generate ISO G code??
hi all if you need some software or manual or technical question for bavelloni machine i can help you
!!!!normaly your local bavelloni distributor must have to help you....!!!!!!!
see you later
bav tec
Hi Bavtec, hi everyone!
We run a Bav Alpa 315 / 4 and the PC broke down, we had to replace it. I now tried to install the software (01/2002) we have on the new XP PC (the dongle is pluged in the paralell port) but it does not work. When I start the setup, I immideatelly receive an error message saying "ERROR 19/61 Enable key missing". What can be the problem. Do I need a new software version or dongle?? I have contacted the local Bav dealer but have not received any anser yet.
I appriciate any help or hint.
Greetings, Chris
Hey dude, maybe you have already solved this issue but just in case:
The problem may be an incompatibility issue since easycad/cam is a way too old SW. Just copy the skwin.dll file to the folders:
c:\windows\System
c:\windows\System32
You can download the file from here
https://skydrive.live.com/?cid=941bc...D6B8026F62!954 (my skydrive account)
Regards
please can you send this file again
NevNavi;1089027]Hey dude, maybe you have already solved this issue but just in case:
c:\windows\System
c:\windows\System32
