587,481 active members*
3,212 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > IMService Servo CNC Router review
Results 1 to 16 of 16
    Nov 2003
    634
    I decided to go ahead and purchase this router.
    http://www.cadcamcadcam.com/
    (It looks like the price just went up $200).
    I bought the basic machine with the Dewalt router option. I did not buy the dust collector because this option takes away 2" from the 4" Z axis.
    I ordered the machine on 12-11-05. It shipped on 12-29-05 and arrived today on 12-3-06.
    If you have any questions about the router, just ask and I'll try to answer.
    Its advertised as a 12" x 12" x 4" CNC servo controlled router. 90% of my work is smaller than this and I always wanted to try a servo based system so I thought, why not?
    Packaging was very good, and everything seems to be in good shape.
    Attached Thumbnails Attached Thumbnails Picture 001.jpg   Picture 003.jpg   Picture 004.jpg   Picture 005.jpg
    Nov 2003
    634
    The machine manual came as a downloadable PDF file. Manuals for the DESKCNC program seem to be limited to help files, and a subsection of the machine manuals.
    3 seperate books came with the Vector CAD software, but I haven't had time to open them yet.
    The control box looks easy to hookup.
    I even received saftey glasses and ear plugs.
    Attached Thumbnails Attached Thumbnails Picture 006.jpg   Picture 007.jpg   Picture 009.jpg
    Nov 2003
    634
    The Y axis came unassembled from the X axis (base). Its a matter of positioning the Y axis properly, inserting 4 dowels, tightening 4 screws, and hooking up one plug in.
    It took about 5 minutes, once I located the proper allen wrenches.
    You need a crescent wrench, 3 allen wrenches, and a hammer to put everything together.
    Attached Thumbnails Attached Thumbnails Picture 010.jpg   Picture 011.jpg   Picture 012.jpg
    Nov 2003
    634
    The table base seems sturdy enough. Its aluminum with 1/4-20 threaded holes on a grid pattern. This will make adding work holding jigs a breeze.
    The X axis runs on 4 Vee rollers. They are designed for a vertical downwards pressure load. There is just a light duty cam follower on the underside which takes up any play.
    The Y axis seem to be loose to me. There are two Vee rollers on the top side with one eccentric Vee roller on the bottom. I'll have to adjust the bottom roller to see if that eliminates the slop.
    The Z axis is on two round rods and seems pretty stiff.
    There are limit switches on all axis(s), and thumbwheels for moving the axis manually.
    Nov 2003
    634
    Ok, After many false starts, I've got the machine to cut. Here are some pictures of it cutting through 1-1/4" hard Maple.
    Notice that I've built a low cost bench out of 2 x 4's.
    I built a simple Tee slot table out of a piece of baltic birch plywood and attached that to the aluminum table top.
    Nov 2003
    634
    I'm pretty happy with the mechanics of the router itself. I would consider it light duty, but the servo's seem to be way better than the steppers that I normally use.
    You can cut very fast and not worry about lost steps.
    I haven't been real impressed with the control software, DESKCNC. I'm used to professional CNC's at work and MACH 2 at home. This controller has quirks that cause it to work differently than I'm used to.
    I can't say that its bad, its just different and that is causing me some learning curve problems. I hope to have it all settled out in a couple of weeks.
    Dec 2004
    1316
    How about a video of those servos moving and the machine cutting.
    Jason
    Nov 2003
    634
    Quote Originally Posted by Jason Marsha
    Jason
    I tried to take a movie with my digital camera. The file is an .AVI file and its huge. I zipped it and its still too big.
    Its a movie of the router roughing out the maple block into a maple leaf.
    I hand carved the original, made a 3D scan of the part, then programmed it with Meshcam. Its cutting a 75ipm, .34" deep, .02 stepover, .125" ball nose router bit. 3 passes to get to a total depth of 1".
    Total cut time with final clean up pass, .008" stepover is 2-1/2 hours.
    I'll try to upload to the video and download section.
    Dec 2004
    1316
    How is the accuracy and rigidness of the machine.
    Jason
    Nov 2003
    634
    Jason
    I haven't measured the accuracy yet, but on my sample leaf, everything was very smooth so that means that the machine is very repeatable.
    Rigidness, I'll say again that this is a light duty machine. Its way better than the plywood machine that I first built and stiffer than my 8020 machine.
    I can flex the router by grabbing it and applying some twist with just arm strength, but again I didn't notice any problems in my cutting.
    Nov 2003
    634
    It looks like my video is too large even in zip mode.
    Nov 2003
    634
    Ok, JFettig helped me shrink my movie file down small enough to upload. I zipped it because AVI isn't one of the acceptable file types
    You will need the DIVX codec of at least 5.2.1 to view this file. If you don't have it, you can download it from the DIVX website.
    The router has been working well. Its been very repeatable for my application so far.
    Attached Files Attached Files
    Jan 2013
    5
    Re: IMService Servo CNC Router review
    I don’t know where to post this, I have this old machine. I’ve managed to be able to use fusion 360 to make gcode with the RS-274D post Processor. Although I get the machine to work sometimes and other times it acts like it’s not getting the gcode sent properly. It fails more often then not. Is there something that I’m doing wrong? Do I need the serial cord shielded? Help ripping hair out ????
    Jul 2017
    348
    Hi train
    U have old imservice
    Jul 2017
    348
    train do you still have defunct company imservice cnc
    Apr 2004
    5747
    Are you starting a museum of obsolete CNC equipment?
    Andrew Werby
    Website
  1. Sherline with IMService SYS-3A Servo System
    By asicman in forum Mini Lathe
    Last Post: 01-28-2009, 04:08 PM
  2. Killed Four IMService Servo Drivers
    By Burn in forum Benchtop Machines
    Last Post: 11-22-2007, 12:53 AM
  3. Hi Speed option for IMService CNC servo router
    By imserv in forum News Announcements
    Last Post: 07-12-2006, 10:16 PM
  4. IMService servo driver
    By CerveloRod in forum Servo Motors / Drives
    Last Post: 06-13-2006, 05:14 PM
