588,490 active members*
3,636 visitors online*
Page 1 of 19 12311
Results 1 to 20 of 372
    Dec 2006
    457
    Buzz's Build Of Joe's Machine
    I have been watching a lot of people build out Joe's machine over the last few months and I have decided to upgraded from my Solsyvia machine to Joe's machine.
    As I already have a machine I am going to cut the parts my self. At present I am starting to break down all the drawings and determine what is what. I believe I have figured out all the plastic parts required.
    Attached is a drawing of the plastic parts I believe I need (I will be modifing the router attachment to accomondate the dust collector). The T's mean the hole is to be threaded (normally with 1/4 threads).
    Anyone see any issues or mistakes?
    Sep 2006
    480
    Looks good Buzz, welcome to the club!
    One thing and it may just be my viewing of your drawing but your router pieces look pretty close together as compared to the spacing with the other parts. Also the motor mounts are taped for 10-24 threads at the motor end.
    What's the overall dimensions of the material you'll be cutting from?
    Look forward to seeing your progress! Post often, everyone likes pictures!
    Aug 2004
    3215
    the file looks correct, except for the portion i maked in yellow, if you tap these 4 holes this will allow the tool holder to go all the way through the Router rear plate and bolt into the Z-Axis bearing block adding an additional 4 places for bolting it together in additon to the 4 outer bolts.
    Looking forward to seeing it cut out and built
    Joe
    Dec 2006
    457
    Thanks guys for the quick responses.
    ccsparky, the router mounts and 1/2 pieces have not been aligned for cutting out for two reasons 1/2 pieces will be moved to a different drawing layout, and the router head need to be redone to accomondate the tool changer stuff and 4.5 Dust collector hose. If anyone has the plans for the z axis head with the 4.5 Dust collector hose and preparing for the Tool Changer (I allready have the attachment for the router).
    The maximum size I can machine is 21.5 * 32.25 the machine area is smaller than this, still working the layout of all the parts to fit nicely in this area.
    Joe
    Thanks for the advice on tapping, I will implement this change.
    Machining will probably not begin for a while as I figure everything out in my head first. For sure I will be posting pictures... as I did for the last machine.
    www.cncmachine.phillipsfamily.ca
    Aug 2004
    3215
    The router mounts are usually 0.75" to help prevent flexing of the router when plunging.
    Dec 2006
    457
    Thanks Joe. That was my understanding on the router plate thinknesses. I just checked the router mount side to make sure of the grove sized and they are at .79". Is the additional width of the slot for the router plates of.04" there for a reason, I would figure you want a very tight fit.
    Aug 2004
    3215
    Quote Originally Posted by Buzz9075 View Post
    If you have purchased material from different sourses, in HDPE and as well as MDF you will find out that not all are the same, in thichness, i learned my leson on this with the groves in the Z-Axis carriage. Even from the same place i.e. Hpme Depot they have different sizes in MDF.
    Dec 2006
    457
    Thanks Joe, good point. I will make sure to setup for the size of the MDF I purchase.
    Aug 2004
    3215
    Also another note, on the Motor support walls the small 0.125 dia. circles are my nick marks i make at 0.02-3" so when i drill the holes in the ends i have a mark to line up with.
    When you start cutting the parts you will see how much time it takes to make them, I do it in my spare time, but still takes a while to do them.
    Joe
    Dec 2006
    457
    Joe, thanks. I was actually wondering what those hole were for, checked out other photos of them from packages and full builds and did not see any holes. Good idea
    Dec 2006
    457
    Started working at laying out the MDF parts and found a few parts are just a little longer than my machine can cut. Was wonder what tricks people are using to cut out the longer MDF parts, I know I can cut them in small pieces and join them together but I would prefer single pieces if possible.
    Thanks in advance.
    Nov 2006
    134
    Buzz, I cut my longer pieces in two on my cnc and then tacked the two pieces to a longer solid piece of mdf(or 1/4" plywood, hardwood, or whatever you have on hand). I then used this to pattern cut a master making one solid piece. After pattern cutting I made sure the length was correct and then I pattern cut the rest of the pieces from mdf by using this master. I hope this makes sense. This worked for me and I could cut the parts out faster by pattern cutting than I could with my cnc.
    Doug
    Dec 2006
    457
    Thanks Doug0, but I am not understand this suggestion. I have never pattern cut before or even reviewed it for that matter. What tools do I use to patter cut? And how does the pattern cutting work, especially with the small slits? Is there somewhere I can read up on this method?
    I have attached what I believe is the parts list required. Page one is the parts required to cut and the second one is the parts to buy. These are work in progress and comments are welcome.
    Attached Files Attached Files
    Aug 2004
    3215
    He is talking about splicing the pieces together and join them with a skin pice glued to the pieces, then use a trim router but which had a bearing on the end usually a 1/4" bit. The bearing will follow the pattern piece and cut the new material to match.
    I would do it with the patern on top and the stock material on bottom and use a router table so the bearing is ontop and you will always have a vertical cut.
    Dec 2006
    457
    Now I understand. Thanks. Looks all to easy.
    Aug 2004
    3215
    Good, Now lets see some chips flying... LOL
    seriously, hope it does work good for you. I really would like to know the difference in between my machine and the one you have build already.
    Joe
    Oct 2005
    1238
    Arrow Flex Couplings
    Hi Buzz,
    The plans for machine #2 seem to be well under way.
    Your web site posted earlier (message #4) is an excellent record of the building of the first machine. Thanks for sharing.
    Shipping & border brokerage for the Lovejoy couplings was certainly expensive!
    Princess Auto (in your hometown I see) has a "flex coupling" that I have successfuly used to join servos to speed reducers. They might be worth checking, to save the extra costs.
    See Page 93 of their catalogue.
    Dec 2006
    457
    Princess Auto is one of my Favorite stores... behind Home Depot and Busy Bee. I will drop by this week and see what they got. I was not looking forward to paying the duty to get more of them across the boarder... all the other companies are fine with shipping USPS. But having $20US turn into about $70CDN is not nice. By chance do you have a part number I can reference.
    Oct 2005
    1238
    Click the catalaoge link added in post #17 above.
    They have several sizes & part numbers.
    Dec 2006
    457
    Dooohhhh ... Sorry I did not see the last line. Wow that is great they got exactly what I want.
Page 1 of 19 12311
  1. My Build - Joe's Kit - Australian
    By crocky in forum Joes CNC Model 2006
    Last Post: 04-20-2020, 10:20 PM
  2. New CNC machine build (big pics)
    By ckm in forum Vertical Mill, Lathe Project Log
    Last Post: 04-30-2012, 11:49 PM
  3. Use the second machine to build the first!
    By Madclicker in forum CNC Wood Router Project Log
    Last Post: 06-27-2007, 05:29 AM
  4. What size machine to build?
    By CNCMP in forum DIY CNC Router Table Machines
    Last Post: 01-04-2005, 08:36 PM
  5. Want to build new machine
    By thuffner3 in forum CNC Machining Centers
    Last Post: 02-14-2004, 03:47 PM
