587,997 active members*
1,624 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach 4 > Mach4 / ESS communication problem - new setup - WakeUpClient error
Results 1 to 3 of 3
    Jul 2008
    35
    Starting Mach4 with ESS plugged in, I get the message "CTftp::WakeUpClient - Error in recv"
    Mach4 v4.2.0.5036
    ESS plugin v285
    Things I've tried:
    System Configuration Utility - everything goes smoothly AND I get ping responses.
    Ran Configurator to reset ESS to 10.9.9.9
    Firewall seems to be configured properly, but to be sure it was not the problem, I have turned it OFF
    Web searches for the error message turn up nothing particularly useful.
    Does "CTftp::WakeUpClient - Error in recv" look familiar to anyone?
    Aug 2022
    37
    Re: Mach4 / ESS communication problem - new setup - WakeUpClient error
    Warp9 website says build 5000+ have issues. Find an older build.
    NOTE!!!! Build 5000 is having probing issues with the ESS plugin... Mach4 Build 4809 with ESS 283 is what we are recommending at the moment. January 15th, 2023
    Go to the document page on warp9 that says
    “Setting up the SmoothStepper and Mach4 Software”
    From warp9 website
    1) Currently recommended for all users:
    Mach4 Hobby version 4.2.0.4809 with ESS build 285
    For Mach4 Hobby versions 5000 and greater, please use ESS build 298.
    2) Previously Recommended Laser users need to use 283 or higher, but it works well for ALL users:
    Mach4 Hobby version 4.2.0.4809 with ESS 283
    3) Previously Recommended for Mills, Routers, Lathes and Plasma units:
    Mach4 Hobby version 4.2.0.4809 with ESS 278.1*
    4a) Previously Recommended: Mach4 Hobby version 4.2.0.4612 with ESS 277.1 or ESS 278.1*
    4b) Previously Recommended: Mach4 Industrial version 4.2.0.4612 with ESS 277.1 or ESS 278.1*
    5) Optional for advanced users: Here is a link to the Mach4 FTP download page, where they have newer development releases. (We don't test against most development releases, so they may have hew features and fixes or they may introduce new bugs and break functionality.) Select an ESS plugin from the next section to go with this.
    X) NOT Recommended: Mach4 Hobby version 4.2.0.5000 with ESS 284 Not recommended at the moment
    X) NOT Recommended: Mach4 Industrial version 4.2.0.5000 with ESS 284 Not recommended at the moment
    EZ
    Jun 2005
    1730
    The error you are getting seems to be the communications between Mach4 and the ESS. Make sure you enabled the ESS plug-in inside of Mach4
    Russ
  1. 6040 conversion to Mach4 with ESS
    By gbward3 in forum Chinese Machines
    Last Post: 05-22-2020, 05:34 PM
  2. Mach4+ESS or Acorn?
    By HoY in forum DIY CNC Router Table Machines
    Last Post: 11-12-2019, 04:34 PM
  3. Mach 3 to Mach4 and ESS
    By Plasron in forum Controller & Computer Solutions
    Last Post: 08-30-2019, 03:16 PM
  4. Mach4 & ESS Warp9
    By rchristie in forum Mach 4
    Last Post: 06-30-2015, 11:30 PM
  5. Mach4 & ESS Setup Problems
    Last Post: 05-14-2015, 12:29 AM
