587,426 active members*
4,545 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > 5v stepper driver or controll board anyone?
Results 1 to 6 of 6
    Mar 2013
    Im building something really small that involves some 5v steppers and i cant seam to find some drivers or a controll board that can run these steppers using mach 3.
    Anyone have any idea on where to find something like this?
    Jan 2010
    2141
    How much current does each motor draw? How many wires does each motor have?
    With a typical current-limited driver, you can drive a stepper motor rated at 5 volts with a higher voltage.
    Or (especially if you can use a unipolar hookup) there are many simple circuits that can drive such a motor with 5 volts.
    Mar 2013
    Well the motors i have are like the ones from a DVD-rom, only thing i know is that they are rated at 5v and anything more then that the heat up really fast.
    Also they are bi-polar(4 wires).
    Thx for your help.
    Jan 2010
    2141
    If you run the motor at a higher voltage than its rated voltage, you will need to limit the current, otherwise the motor will get too hot.
    A simple but not very effective way to do that would be to use series resistors inline with each winding. A better way to do that would be to use a current-limiting driver such as the EasyDriver:
    https://www.sparkfun.com/products/10267
    Mar 2013
    Well can you connect that driver to a interface board like one of those china cheap ones(like this)? and this is also rated at 7v min and 150mA a phase and im not sure if that is to much for my little motor.
    Jan 2010
    2141
    I do not have direct experience with that breakout board, and I do not see a schematic for the board, however it appears likely to me that the breakout board would be suitable.
    I also have no experience using a motor from a DVD ROM. Can you identify the part number of the circuit that was originally used to drive the motor when it was in service inside the DVD ROM?
    If you apply 5 volts to one of the motor windings, how much current does it draw?
  1. Stepper driver board
    By 4lowie in forum Australia, New Zealand Club House
    Last Post: 09-09-2011, 09:31 AM
  2. Help identifying an old stepper driver board
    By spencoid in forum Stepper Motors / Drives
    Last Post: 12-07-2010, 09:32 AM
  3. 6 leads stepper motor connect to TB6560AHQ stepper driver board
    By wf1318 in forum Stepper Motors / Drives
    Last Post: 07-25-2010, 08:19 AM
  4. univelop stepper driver board
    By vicsrc in forum Stepper Motors / Drives
    Last Post: 03-17-2009, 01:51 AM
  5. Stepper motor A vs driver board A
    By tsknutsen in forum Stepper Motors / Drives
    Last Post: 03-14-2009, 02:41 AM
