587,231 active members*
4,884 visitors online*
Results 1 to 10 of 10
    Jun 2015
    28
    Breakout board power, Which Power pack?
    Hey All,
    I wanted to power my Chinese BOB with a power adapter instead of the USB port.
    I have 2 adapters to chose from, 5.3v 500mA or 5v 2.5A.
    Which is better to use to power my chinese CNC BOB.
    Here is an image of the board, for clarification.
    Linrox
    May 2015
    686
    Re: Breakout board power, Which Power pack?
    I'd go with the 5 volt one myself. I don't think the 2.5 amps will worry you at all.
    Rod Webster
    www.vehiclemods.net.au
    ericks Guest
    I agree it's better to use a separate psu. Like Rod said the 5V is fine
    Mar 2007
    2083
    are both power supplies regulated ??
    if both supplies are regulated
    the 5.3V supply can be use as its within the 5V plus or minus 10% limit for TTL logic IC's
    if the 5.3V supply is a phone charger - don't use it , they are not normally regulated
    John
    PS
    the breakout board circuit
    Attachment 406162
    link to the data sheet for the 74hc14 IC used on the breakout board
    https://assets.nexperia.com/document...74HC_HCT14.pdf
    from page 4
    the supply voltage
Name:	74hc14 supply voltage.jpg
    Jun 2015
    28
    The 5.3V was from a old mobile charger. I thought the current might be a bit low, at 500mA.
    The 5V2.5A was from a external usb hub.
    Thanks All for your replies.
    Apr 2014
    432
    I have one of these the best option I believe .
    Jun 2015
    28
    I was looking for one of these but i could not find one available for Australia. And few that i did find were over priced.
    But it's all good now, i'll just use the 5v2.5a power adapter that i have.
    Aug 2005
    1101
    This is the one I recommend for my breakout boards.
    https://www.homanndesigns.com/index....products_id=99
    Cheers
    Peter.
    Homann Designs - http://www.homanndesigns.com/store
    Jun 2015
    28
    I will bookmark this for my next CNC.
    Apr 2014
    432
    Yep that one 4 years down the track and still kicking
  1. Replies: 9
    Last Post: 05-27-2015, 02:55 AM
  2. How to wire my motors power supply and controllers with breakout board
    By madaxe in forum CNC Machine Related Electronics
    Last Post: 05-01-2010, 12:30 PM
  3. Breakout Board, Driver and Power for nema23 - UK supplier?
    By mnbylcr2 in forum Benchtop Machines
    Last Post: 05-21-2009, 05:47 PM
  4. Breakout board - power light indicator?
    By MakotoKamui in forum Automation Technology Products
    Last Post: 03-24-2008, 05:45 PM
