587,103 active members*
3,986 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Question (lead screw bearing support)
Results 1 to 2 of 2
    Jan 2013
    18
    i am building a 4x4 steel table cnc. i will be using a 3/4 4 start acme screw for both the x and y axis. I will also be using lovejoy couplers at the steppers. The question is can i use a Fastenal 3/4 pillow bearing block w/ a 3/4 collar on each side of the block for my leadscrew supports. thanks in advance for your input
    Nov 2007
    483
    Quote Originally Posted by wmpinion View Post
    you sure can
    Have you considered rack and pinion or are you looking for every high tolerances of a screw?
  1. How to mount lead screw inside a bearing?
    By CuttersCov in forum DIY CNC Router Table Machines
    Last Post: 08-13-2011, 01:25 PM
  2. How to make a Lead screw holder / journal /bearing thingy
    By breathe in forum Open Source CNC Machine Designs
    Last Post: 10-15-2010, 03:28 PM
  3. lead screw whip ? bearing to use and why?
    By technomage in forum Linear and Rotary Motion
    Last Post: 05-08-2007, 12:16 AM
  4. Long Lead screw support
    By xyz100 in forum Linear and Rotary Motion
    Last Post: 11-22-2006, 05:28 AM
  5. Lead Screw Support
    By jmytyk in forum DIY CNC Router Table Machines
    Last Post: 08-29-2005, 08:12 AM
