i opened up my g540, to verify that the db9 connectors outer housing is not connected to anything. my idea is to solder a strip of copper across the housings, and solder a wire from that strip into the grounding in my 230 vac outlet. then i could wire the shielding to the chassis part in the connector. does that sound correct? here is a picture of the opened drive, showing what i would like to do:
