587,224 active members*
3,147 visitors online*
Thread: CIMATRON
Results 1 to 5 of 5
    Jan 2024
    CIMATRON
    Its been like a year now that im using cimatron 12. Am i in a right way or I need to change to another one. Can i have some sugestions. It can be really helpful.
    Mar 2009
    1982
    Re: CIMATRON
    Rhino CAM rules, take it as soon as possible
    Re: CIMATRON
    Quote Originally Posted by xyz87 View Post
    Personally, I think the cimatron works pretty well, but since you're all set on replacing it, that means it's probably not a good fit for you.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    May 2024
    Re: CIMATRON
    Can you find out any direct option for assign material for imported IGES file in assembly format because I want to make BOM (Bill of materials) so please share your opinions
    May 2024
    9
    Re: CIMATRON
    First, import the IGES file by going to File > Open and selecting the IGES format. After importing, right-click on each part in the FeatureManager design tree, choose Material > Edit Material, and select the appropriate material from the library. Once all materials are assigned, you can generate the BOM by going to Insert > Tables > Bill of Materials.
  1. Cimatron
    By CadMan_ in forum Uncategorised CAD Discussion
    Last Post: 10-10-2022, 02:26 AM
  2. Cimatron E9 file not opening in Cimatron E10
    By vikas123 in forum Uncategorised CAM Discussion
    Last Post: 01-22-2017, 03:24 AM
  3. cimatron
    By senoj4 in forum Uncategorised CAM Discussion
    Last Post: 11-08-2013, 11:09 AM
  4. new to cimatron
    By tazzydean in forum Uncategorised CAM Discussion
    Last Post: 05-19-2011, 05:25 PM
  5. Cimatron 8.5
    By Mark_H in forum Uncategorised CAM Discussion
    Last Post: 02-25-2010, 10:43 PM
