588,221 active members*
3,766 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > What is the maximum practical speed you could run a stepper at?
Results 1 to 7 of 7
    Jun 2005
    866
    Assuming you had a 23 frame motor with high input voltage. And, you had a high quality driver like Gecko. What would be the maximum RPM that this motor could practicly handle? Could it handle 1000?
    ALso, assuming it is an 8 wire unipolar wired in parallel mode.
    35538
    I think my powermax motors say 1500RPM on them. A guy on the Mach3 Yahoo group using a G-Rex is spinning one at 3000 rpm. It's a 7.5V, 2.5A 311oz stepper using only 30V. I have no idea what rpm it becomes unuseable, though.
    1695
    5000 rpm no load, full stepping, should be easy.
    Aug 2004
    2849
    It really depends on the load......look at the torque curves for the stepper in question.
    Jun 2005
    866
    Wow, these spin faster than I thought. I know the bearings should not be a problem, being the small diameter that they are.
    I'm just looking for some very general estimations is all so I can decide what kind of ratio I want for this.
    Aug 2004
    2849
    I would direct couple a stepper.....and without looking at the torque curves...you'll have to experiment if you want to use pullies and belts....
    Jun 2005
    866
    Well my router is all setup for belts and pullies, plus I have already got actuators all setup. This is the complete assembly, a duplex for each side and all.
    I just need to figure out the pully and belts.
    THe best I got for Torque curves was on the LIN Engineering site:
    http://www.linengineering.com//site/...18.html#Wiring
    My motor is not directly listed there though. The # I have is 5718L-95DE-02
    The 5718L is there, but you see the torque curves are quite different for the various L motors. These were a custom build for a company, so it would not be listed. All i know besides that is this motor has a excellent torque (I have run it before, it is the strongest 23 frame I have felt in holding torque), and is 8 wire.
