587,263 active members*
3,355 visitors online*
Thread: PhotoVCarve!
Page 1 of 6 123
Results 1 to 20 of 133
    Sep 2005
    116
    PhotoVCarve!
    Has anyone been to Vectric's new page? They have a fantastic new product called PhotoVCarve! All I can say is WOW!!!
    Just like VCarve they have a free-trial version of the new software at www.vectric.com.
    Bill Schober
    Apr 2005
    3634
    The quality on the websites photo gallery, wasn't all that.
    They should change the step over or something. One or two photos looked ok, but most had lines, that just kept me focused on the lines, not the photo subject.
    I'm not knocking the software, they should just put their best photos up, to show what the software can do
    http://www.vectric.com/WebSite/Vectr...vc_gallery.htm
    May 2005
    405
    Quote Originally Posted by Switcher
    Think you have missed the function of the software.
    It is not 3D image software. Its designed to give a good replication of a photo. Its 2D in presentation. It is producing lines of varing widths dependant on shade. It will always have lines but I assume you can change the spacing to suite your requirements. An interesting idea. May have some application in memorial work.
    Jul 2005
    253
    The software’s pretty cool, you can change the line spacing and the cut depth to get different effects. I'll attach two screen shots. One is using a 60-degree Vbit with a line spacing of .05 inches. It gives a pretty cool effect and I've actually cut this one and it comes out really nice. The smaller the bit and the more lines you can get the sharper the image seems to get. It seems part of the trick is making sure you have enough contrast between the cuts, so painting or staining your cuts something darker then the surface is the way to get the best looking piece. The second image is using a 1/8-ball nose bit with a line spacing of .013 (so it overlaps). You can see you can get some cool 3d effects too.
    It takes a little playing around with the software to find the settings you like. But compared to some of the other photo to gcode programs I've tried this one actually creates something that looks like your photo and without much work at all.
    Take it easy.
    Jay (www.cncjay.com)
    Sep 2005
    116
    Nice Jay,
    As I understand it, if your varnish your wood first then cut it and stain it the stain is only applied to the cut areas. I think this would work nicely on your first one. My CNC machine is down at the moment, so I can only play with PhotoVCarve and imagine what might work... :violin:
    Bill
    Aug 2005
    597
    Thanks for the positive response!
    Hi Switcher,
    The Trial version of PhotoVCarve will allow you to cut the 4 samples shown below, at any size on your own CNC machine. It will also open your own photographs, calculate and preview the toolpaths, but not save the cnc code.
    The key factor about PhotoVCarve is that it machines very realistic results using lines much quicker than any of the grayscale height map products that typically have cutting times of many hours+, with results that are very dependant on the lighting and shading in the original photograph.
    The technique used in PhotoVCarve works regardless of what the photograph looks like. Having said that, high contrast photographs / images will give better results, and the software includes an option to increase the contrast and instantly preview the results so you can see what the finished piece will look like.
    We have a web page that explains how the process works,
    See > How PhotoVCarve works
    Hope this answers your questions,
    Tony Mac
    Attached Thumbnails Attached Thumbnails Cute_Puppies.jpg   Big_Ben.jpg   Baby_Boy.jpg   Woman.jpg
    Aug 2004
    3215
    Can someone do a tutorial, or demo from start to finish, not of the actual program workings those are clear on the program website, but of material setup, preperation and how to get the proper shading. (materials and applying the effects) that is what i'm inclear about. pictures would help alot.
    Thanks, Joe
    Edit: i just looked at the link Tony provided and it explains some of it, but like to see pictures of the proccess and all steps.
    Aug 2005
    597
    Joe,
    The general procedures are outlined on our web site.
    See the link > How It Works
    Things to remember are,
    Material / Machine Table must be Flat
    The machined grooved must be a different colour to the material surface
    Typically fairly shallow grooves,
    0.020" for small designs around 3" high
    0.080" for designs around 12"
    Experiment with different depths in the software to see how a deeper cut produces fewer lines and less detail.
    You must use a V-Bit / Conical Cutter otherwise the width on the lines will not vary
    When cutting wood the Line Spacing needs to be 120%+ to leave a small flat region between each line / groove, stopping the wood from going fuzzy.
    Engraving Brass, machine the part, paint the grooves / piece black and polish the surface to remove the excess paint. Altenatively, use a 'Blacking Fluid' to etch the brass to black, then polish the surface clean leaving the balck in the grooves.
    Hope this helps,
    Tony
    Sep 2004
    107
    Quote Originally Posted by bsimages View Post
    Nice Jay,
    Bill
    Is this how they get those "black lines". I was trying to figure that out. I'm going to try out the carve product today or tomorrow, but was definitely looking at the photovcarve.
    -Matt
    Aug 2005
    597
    Hi Matt,
    The key to the PhotoVCarve process is to have contrast between the surface and the machined grooves.
    The best way to achieve this is to varnish / seal the top surface of your wood.
    Machine the grooves
    Apply a dark stain and wipe / sand off the excess
    Machining 3D Lithophanes with PhotoVCarve is a very different approach, and there's a tutorial on this off the web site.
    Let us know if you have any questions,
    Tony
    Aug 2004
    3215
    Here is the Photo i cut into Corian (8.5"x11" White) using the Photo-Carve, I could not believe how It came alive, and the cuts were great in Corian.
    I cut the file, then blow out the Corian dust from groves using compressor, then just use plain old fast drying Flat Black paint i had sitting around. Then used sand paper sounge to sand the surface back down to the white Corian, took over to the sink rinsed off, and wiped dry. And you see the results, when you start looking you can see details in the picture, Even lettering on the Boy's shirt. The preview in the software looks good, but the finished product is even better.
    The whole proccess works best when having a nice material to start with.
    60deg. V-bit, 20ipm, took 56 mins
    1st picture is after cut and corian dust blown off.
    2nd picture is finished product.
    Joe
    Apr 2005
    3634
    I think the type of cut, I like best is the one with 674 lines, and 4 steps in "Z", Looks way better to me.
    I noticed you can adjust the angle of toolpath, can that be a different angle in each "Z" pass?
    What kind of limit is on the trial version?
    Apr 2005
    3634
    Just curious, how do you enter a License Code?
    When you click on "Help | Enter License Code" Nothing happens.
    Aug 2005
    597
    The Trial Version cannot be turned into a working version.
    Customers receive a new download link to the Full version + license code.
    Regards,
    Tony
    Feb 2012
    Im new to the CNC world, and stumbled across the PhotoVCarve software... wondering if you need a postprocessor? or is this an all in one deal...? forgive me if this seems to be an ingnorant question - really a newbie
    Dec 2005
    238
    Quote Originally Posted by jzello View Post
    Hi Jzello and Welcome.
    PhotoVCarve has its own post processors to suit common controller software and it can be altered to suit personal requirements.
    I suggest you download the trial version and cut on or 2 of the examples included with it. This will ensure it is compatible with your machine before you buy.
    Cheers
    Peter
    The ingenuity of idiots is unlimited.
    http://www.youtube.com/user/cncnutz
    Apr 2005
    3634
    Thanks, Tony
    Apr 2005
    3634
    Tony,
    How can I add multiple "Z" passes?
    And:
    Thanks.
    Aug 2005
    597
    Hi again,
    Good question.
    The maximum depth a tool can cut is specified in the Tool Database.
    For example, entering a Carving Max Depth = 0.080"
    Selecting a cutter that has a Pass Depth = 0.040" = 2 passes
    Editing the parameters for the cutter to have a Pass Depth = 0.020" = 4 passes
    The Tool Database is fully editable and yo ucan setup your own tooling list.
    Hope this makes sense?
    Let me know if you need more guidance,
    Tony
    Aug 2005
    597
    Hi again,
    Just realized that I made a mistake when stating that the Trial version will only let you cut the 4 sample files - NOT TRUE
    The Trial Version will let you CUT ANY Photographs but the results will be watermarked.
    So you can actually cut yor own pictures!
    Sorry about that,
    Tony
Page 1 of 6 123
