588,471 active members*
5,395 visitors online*
Results 1 to 5 of 5
    Mar 2009
    199
    770rpm's on the 1100?
    How hard do you think it would be to put the 770's spindle motor on the 1100 so that I can have twice the RPM's?
    Jun 2006
    2512
    It's not the motor that's the problem it's the spindle itself. The 1100 spindle is not good for 10,000 rpm. However I think the 770 spindle is to short to fit in the 1100 head.
    The simplest solution would be to buy the complete 770 head, including spindle and motor. Look at the last item at the bottom of this page:
    CNC Mill Upgrades and Maintenance Products | Tormach | We provide personal small CNC machines, CNC tooling, and many more CNC items
    Phil
    Quote Originally Posted by howecnc View Post
    Mar 2009
    199
    I only see a few problems with that idea. The size of the head and bolt patterns are different and I want to continue to use my power draw bar and eventually the tool changer.
    Thanks,
    Jun 2006
    2512
    I believe the 770 spindle is shorter. In which case how will you mount the drive pulleys and the powered drawbar if you use the existing 1100 head casting.
    Phil
    Thanks,
    Mar 2009
    199
    I guess I could have the 1100's spindle cartridge rebuilt for the higher rpms.
    Then I would only have to adapt the Motor and drive.
    I don't think I could do any of this without the support of Tormach.
  1. 1100 on its way!
    By dbrija in forum Tormach Personal CNC Mill
    Last Post: 02-18-2011, 02:12 PM
  2. Engraving on the 1100
    By kevperro in forum Tormach Personal CNC Mill
    Last Post: 01-21-2011, 08:37 AM
  3. 1100 on it's way
    By Etced in forum Tormach Personal CNC Mill
    Last Post: 01-03-2011, 09:52 PM
  4. PCNC 1100 help
    By jedge in forum Tormach Personal CNC Mill
    Last Post: 10-23-2010, 11:58 PM
  5. Anilam 1100
    By english bob in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-09-2008, 04:12 AM
