Originally Posted by
mactec54
Yes, there is something not right with that VFD Drive, it should not be that difficult to set up
The Spindle must have the 4th Pin Grounded you can't run it unless it is Grounded, this is very dangerous. below is a snip of what you have to do if your spindle is water cooled it's a little different if you have an Air Cooed Spindle, but still has to be done before you apply any Power, this is quite common for some of these Spindle to not have the Ground connected.
Your Power supply is all good there should not be any Fues in these lines if anything you should be using a Breaker so the VFD Drive can be isolated in the Cabinet if need be.
Put your original VFD Drive in place, and I will help you get the remote control working, almost all VFD Drive have the same setup for remote control so there must be a way to get it working with your control or you will have the same with all the VFD Drives you try
Do you have the manual for the first VFD Drive you used if you post it, I can see how it needs to be controlled, and what Machine Control are you using
