Originally Posted by
mag409
Jim,
Per your suggestion I contacted Hypertherm tech and after trying a few things the tech decided to replace the unit. I got the new unit hooked up today and tried to cut with the same results. The difference now is I cannot cut any thickness material and I am getting a 021 air pressure fault. This is new. Have not had any issues with air supply. I bypassed the shop system and ran straight from the compressor with no changes. I thought maybe there may have been a blockage within the machine or torch lead and all checked out fine. Any ideas or reasons behind the unit getting an air supply fault?
Some additional info: I unhooked the THC controller and used the manual torch control that came with the unit. I fire the torch and it runs for a few seconds and faults out for air pressure. The little bit it cuts looks good. The incoming air pressure maintains 90PSI after the filter at the machine. I have run the machine previously while also running other air tools in the shop, so I don't think I have an air supply issue. No fault shows up on Mach when the unit shuts down. I also tried running the machine in the manual air adjust mode and took it up and down with no change. Unlike the original problem, this new one now occurs with the 45 amp consumables in the machine as well. Is there an internal adjustment set at the factory for the air fault?
Thanks,
Mike
