587,665 active members*
3,521 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma U100 RS232 mystery
Results 1 to 5 of 5
    Mar 2009
    9
    Allo,
    We use on our okumas U100 the Read Write Get Put function (RWGP) to send data to a SQL database for various data points via RS232C communication.
    There are no issues with this data. All looks good
    The problem i have is when I want to use PIP function we get parity error on the same channel.
    It seems the PIP function and the RWGP function use different RS232C parameters. But they are not visible in the parameter list....
    What happens is if I set com parameters for RWGP i get parity problems on the PIP function.
    If I set parameter for PIP function, I get the errors on the RWGP function...
    Any idea why that might be?
    Thanks,
    Aug 2011
    423
    Re: Okuma U100 RS232 mystery
    PIP or D-PIP?
    They are different.
    "Imagination is more important than knowledge."
    Mar 2009
    9
    Quote Originally Posted by kurmay View Post
    PIP or D-PIP?
    They are different.
    Definitely PIP for transfer programs
    Aug 2011
    423
    Quote Originally Posted by dafrenchman View Post
    Which alarm occurs when use PIP function?
    Can you share screenshots?
    Mar 2009
    1982
    Where the "RWGP" philosophy comes from?
    check once again if some D-PIP ( settings backup ) parameters are not different from write / read parameters.
  1. OKUMA OSP U100 WAY LUBE TIMING LU15 LATHE
    By okuma1984 in forum Machinery Manuals / Brochures
    Last Post: 05-09-2021, 07:01 PM
  2. Okuma RS232 Conversion
    By Fireater in forum Okuma
    Last Post: 04-21-2021, 01:37 PM
  3. Replies: 8
    Last Post: 09-25-2014, 02:58 PM
  4. Okuma lathe RS232
    By MIDDEN300 in forum Okuma
    Last Post: 08-08-2014, 11:05 AM
  5. Replies: 0
    Last Post: 02-05-2012, 08:06 PM
