Do you sharpen drill bits by hand on a bench or pedistal grinder?
Yes I do it all the time!
No, they never cut right!
Sorry, I don't know how to do that!
Its better to throw them away!
No, we have a drill sharpening machine!
What's a drill bit?
What's a drill bit?
What's a drill bit?
do it all the time, or at least did until i made my drill sharpening jig. Hand sharpening of twist drills seems to be one of points of delineation between those who really know what they are doing and and those that don't. It shouldn't be that way though, its just not that tough to do. It does take some skill vs just plain old knowledge, but that will come quickly with some practice and everyone should learn how, its a basic shop skill. with a drill point gauge, nicely dressed wheel and a spare 3/8 bit, long before you grind your way through that bit you'll have the hang of it!
Mr Mcgyver I could not disagree more!!!!Originally Posted by Mcgyver
I have demonstrated the procedure to, and tutored in drill sharpening techniques, many, many people. There exists a percentage which I put at around 20% that just never get the knack. It is like any other acquired skill, some people pick it up almost naturally, some will get there over a variable time period with persistence and practice and some will never get there.
forget 20%, did you know half the people out there are of below average intelligenc?Originally Posted by Geof
Geof, or shall i call you Colonel Pickering,A sad portion of that 20% maybe people who just don't have the capacity to learn, and a still sadder portion might not want to learn, but i maintain that most of us, if we puzzle out the shape of a well ground bit, the motion we'd have to give it across the wheel to obtain that shape and a way of measuring (and understanding why) the lip length and angle, could be taught. next thing you know we'll have wager going 'the rain in spain......"
Lakeside i see your point for production, but for commercial jobbing, maintenance, toolroom or home (as you point out) it's neccessity - a skill that would be beneficial to acquire, most probably have it except for many of the home shop guys. I mostly use the T&C grinder now because drills sharpeded with it are so accurate, but thats a luxury few have and and mostly drilling isn't a precision op (oops there's another pandoras box) .
I have been called a lot worse than 'Colonel Pickering' so I will not quibble.Originally Posted by Mcgyver
Regarding your other point in your first post you said "everyone should learn how" with which I disagreed; (does my grammar come up to a Higgins' standard?) now you "maintain that most of us......could be taught".
I will respectfully point out that 100% - 20% = 80% and I think most of us will agree that 80% is most of us. Which is probably the first time Pickering and Higgins agree.
I agree with you 100%. Some people will never get it. The poll is asked to those that are or should be Machinists. If you can not grind a drill or a tool bit How dare you call yourself a Machinist
Success is the ability to go from one failure to another with no loss of enthusiasm-Sir Winston Churchill
I am 69 years old and I have hand sharpened more drills than you want to know about The enquiry is meant for McGyver however I did not know that sarcasm was the order of the day seeing that I specifically asked McGyver:rainfro:
At today labor rate and the fact that you can never really grind a drill point with both flutes cutting at the same time unless you use a comparator. The cost to grind a drill in other than a home shop or to be used in a manual machine is not worth it for a 3/8 drill. As a note I did tool grinding for 10 years and can split point. But unless there is no new drill a regrind will only be use if it the last option.If your a job shop I can see why you would, but a manufactor would not was the time Boston shop rate $95h/60m=$1.58/min x 5min(regrind time)=$7.50 what the cost of new?Buy a dozen at a time and send out for regring when you have many to do The shop we send to charges $2.50/drill under 1/2 and that is with a split point
$95/hr? Get out of the cities and get some stuff done without breaking the bank. But even at half that rate, It just makes no sense to stand over at the pedestal grinder and sharpen a drill for more than a few seconds.
:rainfro:
If you do not know how to sharpen a drill or end mill by hand, you would not worry agian when you own the sharpening machine.
Just take 30 seconds, you would get the new tool~
More information: http://www.atron.com.tw/uwish/front/...681&Part=video
Sincerely,
J.S.
www.atron.com.tw
E-mail: [email protected]
Skype: yaams0939
I know this reply is uber-late but I just joined the community and this was one of the first things I've seen!
I wasn't allowed to use a drill bit until I knew how to sharpen one. Same went for lathe tools. Wasn't allowed to use carbide inserts until I could grind my own HSS. =)
Manufacture huh, well I have seen the argument on here before about custom made tools "cutters" made by a tool maker for a specific job and the argument that a insert cutter "off the shelf cutters" and a cnc has out dated custom tool grinding. I think that is rediculous, it makes no sense to make a bunch of tiny cuts "adding much longer run times", instead of grinding a custom tool to cut that shape out in a few passes. Manufactures are after speed, and custom tool grinding saves alot of time, electricity, and machine wear & tear when it comes down to it. This is common sense to anyone that knows anything about manufacturing. For 1 off parts if you can get by with a off the shelf tool, then why not add a little longer run time vs. grinding a tool. Now grinding a drill bit I agree a manufacture "most likely" wouldn't regrind little drill bits. It's a valuable skill to have, we and I in our shop re-grind drill bits by hand depending on tolerances of the part and we grind our own lathe and mill tooling along with tool and die making.
When I was young my Dad (machinist all his life) tried to teach his dumb arsed son how to do it. However, I could just never quite get the hang of it. Well many years have passed (along with my Dad) and a friend (Mentor) got me to doing it in 15 min!
Being out in the country, I can't just run down to the nearest supply house especially on a Sat. or Sun. when I break the cotton picken drill. So this skill is handy to have for those times as well as when you need a different point for some specific material to drill a couple of holes and finish the project. No matter how many drill you try to keep as backup, there are times you NEED to have the skill!
Art
AKA Country Bubba (Older Than Dirt)
If there one area that we as a trade have lost it is the manual tool grinding of both mill and lathe with most shop going to insert tooling the young guys just don't have the opportunety to do this much and it's a skill as Bubba said we need at times
i sharpen large drill by hand , i ve seen lots of guys who can sharpen a drill then blow it when the try to split point it , i can t tell you how many times i ve picked up a drill and someone has ground across the cutting edge leaving a negative rake at the most critical spot on the drill , which is at the point , i don t know how these things cut sometimes
shear & horse powerOriginally Posted by dertsap
ahhhh but my dear Colonel Pickering, everyone should and most could, the two are not incompatible. its splitting the point that we are having difficulty with![]()
in my opinion and experience that there is only a small percentage of machinists who do things properly in the shop ,be it stupidity or laziness ,
this is what makes us professionals , not everyone can do it ,
I still have the drill gage I made as an Apprentice. After I made it they gave me a bunch of drills to sharpen. Then I had to drill holes, then they checked them for size, straightness, finish, etc. Also learned how to do a lot of things that seem to be unheard of today. I set up my sine bar to check an angle and the Inspector remarked that it didn't look like a very accurate way to check it, why didn't I use a protractor and a magnifying glass if I really wanted it accurate.![]()
