588,506 active members*
5,797 visitors online*
Results 1 to 2 of 2
    Nov 2022
    Mach 3 for my Suregrave Excalibur
    Hi experts,
    Can I control a Suregrave Excalibur that runs from a serial port, with Mach 3?
    If so how?
    Many thanks,
    Paul.
    Nov 2013
    4614
    Re: Mach 3 for my Suregrave Excalibur
    I doubt you can control a serial input machine with Mach3. Aside from which Mach3 is obsolete, all development ceased eight years ago...it still works and lots still use it, but if you want something
    current then use Mach4.
    Not that Mach4 is going to help you either. Mach, either 3 or 4, produces numeric data to a motion controller and the motion controller generates pulse stream outputs to the motor drivers etc.
    The communication from the PC/Mach can be and often is serial but is not compatible with your machine.
    If you stripped your machine down so you could access individual motor driver inputs and feed those from a Mach motion control......that would work.
    Craig
