587,369 active members*
3,400 visitors online*
Results 1 to 14 of 14
    Sep 2003
    33
    Drill & Tap Combination "DRAP"
    Anyone used these before? I am having a problem with run a M4-0.7 thru 3/8thk Aluminum. They keep snapping off. Also running 1/4-20 DRAP. Any help would be much appreciated.
    Apr 2003
    1876
    I've seen them, but have stayed away from them for just that reason. I would think a tool like that would only work on very specific applications. Let us know how you resolve the issue.
    'Rekd
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    4826
    To tap that thickness without a chip clean move ( or three) would be equivalent to tapping 75 mm plate with a 24 mm tap without stopping to clear the chips. You can program two or three G84's in a subroutine to provide the chip break and clearing.
    You would be better off to use a seperate tap with a spiral point (for a through hole), or use a cold forming tap.
    For deep threaded holes, you are usually safe to increase the tap drill diameter just a whisker, in order to make it easier to cut threads. Unfortunately, the DRAP locks you in to a process with very little flexability.
    First you get good, then you get fast. Then grouchiness sets in.
    Sep 2003
    33
    Yeah that is what I thought I have already changed to a drill and tap. Just not enough clearance.
    106
    I use them on 11 gauge CRS. Only to avoid a tool change. The part I use them on has 6 1/4-20 holes thru. So I use a DRAP and first drill all 6 holes at 110 SFM then go into tap mode at 60 SFM to tap the six holes. Not much of a time savings but every bit helps.
    Jul 2003
    41
    I've used an M4 drap on nominally 3/16" tk. Al and don't ever remember breaking one. I did it to save on tool holders--what's your excuse? I spot drilled with an engraving point but a center drill or real spot drill would work also. I wasn't concerned about location as much as a burr-free, countersunk top surface. I drilled through the part at high rpms, then called a G84 which was ridgid tapping mode. This was a very slow operation since the spindle was always changing speeds or direction. You have to use a drap in a hand fed drill press and a tapping head or in a CNC machine with ridgid tapping! A floating tap holder is not going to be ridgid enough for drilling in a CNC and you can't use a ridgid collet or tap holder in a CNC without ridgid tapping.
    Feb 2004
    142
    i personally use roll form taps with everything i do... sure it takes 3 holders to spot, drill and tap but youd be hard pressed to find a better tap for longevity i like the feature that mazak added into their m640 where you have a full retract style tapping so you can take depth cuts with a tap for chip clearing... i dont know if any other companies offer this because ive worked solely with mazatrol for the past 5 years with only a little fanuc turning and fadal milling experience prior
    Oct 2003
    352
    I never use one of those unless the material is less than the length of the drill flutes. I am not sure if those are capable of drilling and tapping at the same time. If they are, I will be surprised.
    Good luck.
    Oct 2003
    352
    Maybe I should proof read before I hit send. I mean "material thickness< drill flute length"
    Feb 2004
    142
    only way i would ever use a drap in thick material would be if it were a fine thread and i was spinning the tap at like 1300 rpm... like i said before roll form works for me... i can tap at 4000 rpm with a 6-32 tap 3/4" deep with no problem
    Apr 2015
    7
    Re: Drill & Tap Combination "DRAP"
    Is there such an animal as a thread forming drap ? (Combined drill & thread forming tap)
    Apr 2015
    7
    i answered my own question; it's not possible to make a combined drap-thread forming tap since the final minor diameter of the threaded hole ends up smaller than the drill diameter. (Thread former displaces material towards inside of hole)
    Lol, would make a good trick question though.
    Aug 2015
    108
    These work better. They max out at 2.5 x D.
    The tools I'm referencing are on pages 1 - 8.
    https://www.vargususa.com/portals/0/...ex-catalog.pdf
    Apr 2015
    7
    INTERESTING! thanks!
  1. Replies: 5
    Last Post: 01-12-2014, 07:07 PM
  2. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  3. What's the difference between "drill rod" and "plated steel rod"?
    By Robotics Guy in forum Linear and Rotary Motion
    Last Post: 02-06-2011, 05:16 AM
  4. 304SS Tube 3" (1/16 wall) x 19.5" Cut-Off, Turning, Drill or Punch
    By onecoolone in forum Employment Opportunity
    Last Post: 11-19-2008, 03:17 PM
