588,340 active members*
5,441 visitors online*
Results 1 to 13 of 13
    May 2007
    7
    Smile CNC Bridgeport II interact 4 Tnc 150
    Help
    Hi To all I am new of this forum
    I have a Bridgeport series 2 interacts 4 control cnc Heidenaim tnc 150
    I have lost the parameters it plots
    I have found in internet the parameters of the tnc 155 but in tnc150 everybody don't enter
    someone has for case the parameters of the Tnc 150
    Thanks to everybody Franco
    Nov 2004
    3028
    TRY THESE.
    George
    Attached Files Attached Files
    May 2007
    7
    Hi MachinTek
    Thanks of the fast ultra answer
    Feb 2006
    27
    George
    On the pdf you attached there are several empty spaces, 36-39 and 44-49, do i just leave them blank or insert 0 instead?
    Cheers
    Chris
    May 2007
    7
    Hi George
    36\39 - 44\49 the empty spaces are Zero
    Franco Greets
    Nov 2004
    3028
    Certain parameters are machine specific. Such as backlash and travel distances from home to extreme limits. That is why they are blank.
    George
    Feb 2006
    27
    thanks for the replys, I have entered the machine parameters as per the pdf above, and following the instructions in the manual the machine goes to manual operation asking to pass over x/y/z/iv reference marks but nothing wants to move, any ideas anyone? I have tried the MOD code 84159 to disable the software limits but still nothing moves!
    Chris
    Nov 2006
    251
    Push the orange start button first then keep pushing the green cycle button until it passes over x y z axis regards greg
    Jun 2008
    3
    if you still need the parameter of nc150 i have it notepad you can send it via computer
    my e mail [email protected]
    send me i will reply you as soon
    hasan wafa
    May 2007
    7
    Bridgeport serie II interact 4 parameter tnc150
    hi
    Have you arrived you for email?
    also find them in fully grown Acrobat reader to the beginning of the page
    to the answer of MachineTek
    these are the tnc150 parameters with bridgeport 2 interacts 4
    the spaces are zero
    Ciao A Tutti
    May 2007
    7
    You greet to Everybody
    I have a question with the personal computer I don't succeed in sending the data in the TNC 150 them I can receive I don't understand as can be.
    Cimco transmits them but I doesn't succeed in finding them in Tnc150
    does the cable seem that I/you/he/she work perhaps I have some parameter of car from to activate?
    Thanks Franco
    Nov 2004
    3028
    Backlash can be ZERO. Travel limits need numbers because ZERO would not allow movement.
    George
    Aug 2008
    problem with interact 4 series II bridgeport
    Hi there! I have a Bridgeport Interact 4 Series II with a TNC 150 control here. I've just found the parameter in PDF file right here and it seems great. Here's my problem when i'm ready to go on manual mode.... it flashes GROSS POSITIONNING ERROR B.
    THEN i have to turn off the machine and turn back on.. can someone tells me why there is this problem?? thank you so much!!
  1. Bridgeport Interact 412/Heidenhain TNC 151 HELP?
    By larrynsr in forum Bridgeport / Hardinge Mills
    Last Post: 03-17-2012, 08:21 PM
  2. Bridgeport Interact 316 VMC
    By L. Sakthivel in forum Bridgeport / Hardinge Mills
    Last Post: 05-05-2007, 03:07 PM
  3. Interact 1 mk 2 bridgeport question
    By greg b in forum Bridgeport / Hardinge Mills
    Last Post: 03-22-2007, 01:15 PM
  4. What VDU for Bridgeport Interact Series1 ?
    By awemawson in forum Bridgeport / Hardinge Mills
    Last Post: 03-10-2007, 08:18 PM
  5. Bridgeport Interact 1 MK2
    By Leyland 472 in forum Bridgeport / Hardinge Mills
    Last Post: 10-20-2006, 12:44 PM
