587,647 active members*
3,577 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > Can I use Fusion 360 to produce sectioned (sliced) cutting files
Results 1 to 2 of 2
    Feb 2010
    8
    I am a retired artist, with a few years of CNC wood cutting experience. The art pieces that I want to produce in ZBrush need to be sliced into segments of no more than 3" thickness so I can cut them on my machine. I really like the many options for that Fusion provides for3d cutting strategies. Is there a way to slice the STL files into segments, or do I need to do that in ZBrush to stay under the 10,000 poly limit for STL import? I am not sure I can decimate these files to 10K and maintain the level of detail that I need to capture the scene. Is there a work around for that STL size limit, or has it been increased? Any recommendations for getting from my large STL or OBJ files output from ZBrush to Gcode for a ShopBot would be appreciated. I have used other CAD programs designed for sign makers, but they cannot produce the fluid 3d drawings that Zbrush is capable of. But it has no CAM component so I need to bridge that gap myself.
    Thanks in advance for any suggestions
    Bob
    35538
    Re: Can I use Fusion 360 to produce sectioned (sliced) cutting files
    You can try MeshCAM.
  1. How you open up saved project files in Fusion 360
    By Rotax91 in forum Autodesk CAM
    Last Post: 10-19-2015, 07:50 AM
  2. 3d Scanner to produce STL files
    By speedtwin69 in forum Taig Mills / Lathes
    Last Post: 10-04-2014, 06:12 PM
  3. Replies: 0
    Last Post: 09-26-2013, 07:32 PM
  4. Replies: 0
    Last Post: 07-08-2013, 03:26 PM
