588,619 active members*
4,508 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > CNC Project !! AMA25LV (G0704) Mill !!!!!!!
Page 1 of 28 12311
Results 1 to 20 of 552
    Sep 2014
    286
    Hi chaps,
    Im new here but i would like to share my current build with you all. This is my new AMA25LV Manual mill that has only been used for a little while and i purchased it with the intention to convert it to CNC.
    Here are some pictures of the current set up !!
    Ive got the following to build the machine:
    12v Power Supply
    AMA25LV Machine
    Nema 23 CNC Stepper Motors High Torque
    Nema 34 CNC Stepper Motor High Torque
    Break Out Board 5 Axis USB Control
    M542 CNC Driver
    M335 CNC Drivers
    Tormach MT3 Spindle Adaptor
    Emergency Stop Button
    Multipul CNC tools ( Carbide )
    Ive been designing the machine and the set up i would like. Please let me know what you think about it
    Ive got the bracket and ball screws coming from Automation Technology at the end of the month so they will go straight on. I'll need to grind out the XY base plate to allow the all screw place.
    Really looking forward to this project !!!!!!
    Cheers,
    Olly.
    Jan 2009
    234
    Re: CNC Project !! AMA25LV (G0704) Mill !!!!!!!
    Love the solid works model care to share it?
    Machines: Grizzly G0704 Mill W/ 3-Axis DRO | Birmingham 12X36 Lathe W/ CNC Retrofit PMDX-126/107 W/ESS 3ph W/ WJ200 VFD
    Sep 2014
    286
    Of corse, send me your email
    Jan 2009
    234
    Thanks, Best model I have seen yet.
    Sep 2014
    286
    Thank you what do you think about my setup ?
    Sep 2014
    286
    I am a design engineer I use CATIA V5 at work but use SolidWorks for my own use as in that is what I initially trained in
    Sep 2014
    286
    Just started stripping the machine down and cleaning it all up I found that the under side of the slide ways where very stiff and in bad condition ! I had to Lap them all in to remove dents and odd issues ! I ran the DTI across the table and it was reading -0.005 mm across the full x travel. I then did the Y and got +0.012.
    Some picture of the dissembles.
    Now it is dissembles I shall do a better CAD model of it for you all. I may start making some custom brackets for you if you want when It is CNC'ed up !!
    Attachment 255258Attachment 255260Attachment 255262Attachment 255264Attachment 255266Attachment 255268Attachment 255270
    Please let me know if you want some more detailed pics
    Also does anyone know what motor couplers are required for the Nema 23 in XY and then for Z the Nema 34 ?
    Cheers,
    Olly
    Sep 2014
    286
    I also think I have a issue with the electrics. I have this set up:
    Attachment 255308Attachment 255310Attachment 255312Attachment 255314
    When I move the motors they turn way too much for the value shown. Also they sometimes stall. Not sure what to do.
    Also the slide ways on the machine seen to Jam up when you try and slide them manually:
    Nov 2009
    4415
    So the motor tuning is wrong. Since there is no gearing. it should be 200 steps per revolution x your microstepping value. Once you install ball screws or whatever it will be 200 x microstepping value x gear ratio. Accel and velocity will have to be adjusted to not stall.
    There arent really any default settings that would work across the board. If there are, they would have to be extremely conservative just due to the different set up abilities of the user.
    A lazy man does it twice.
    Sep 2014
    286
    Where do you get the micro stepping value ? I don't have additional micro stepping drivers ?
    Nov 2009
    4415
    If you look at your picture 4, it shows how the dip switches should be set to obtain different microstepping values. For example a 1.8 degree stepper has 200 steps per rotation. 200 x 1.8=360. For resonance issues you want to break the steps down into smaller increments and for improved resolution (to a degree can not make the machine accurate to .00001).
    Your drivers allow full step (200) half step (400) 1/8th (1600) and 1/16th (3200). I would use the 1/8th (1600) myself first. Then in motor tuning put 1600 in the steps per box, hit apply. Now every 1600 steps will create a single revolution of the stepper.
    Feb 2006
    7063
    Quote Originally Posted by Fastest1 View Post
    Umm.... no. The setting in Mach3 sets the steps per unit, either per inch or per millimeter, not one motor rev. In most cases one rev of the motor will be either 0.2" or 5mm, as determined by the screw pitch. Assuming the screws are metric, with 5mm lead (5mm/turn), the number entered into the StepsPer setting in Mach3 will be one of the following:
    For inch default units: StepsPerRev * 25.4 / 5
    For mm default units: StepsPerRev / 5
    Regards,
    Ray L.
    Sep 2014
    286
    Not sure if you can see them, ill get a link.
    Sep 2014
    286
    So what switches would I turn on and off ? I'm rubbish with electrics !!
    Attachment 255422Attachment 255424Attachment 255426Attachment 255428Attachment 255430Attachment 255432
    Sep 2014
    286
    I work in MM. Here are the specs for the ball screws :
    Sep 2014
    286
    Thank you so much mate, really means a lot !!
    Sep 2014
    286
    So I would do 1600 x 5 = 8,000 steps per revs. ?? Seems a lot !!
    This is my current set up:
    Attachment 255440
    Attachment 255442Attachment 255444
    Sep 2014
    286
    What's velocity and acceleration ? Where do you get these figures from ?
    Quote Originally Posted by onocyclone View Post
    A lot to cover about your electronics but to start, velocity would be inches per minute or mm per minute in your case, it's how far the axis would travel in 1 minute.
    I would start at 600 mm/min, may be able to go faster but we'll see, you say you are using a 12v power supply, this will seriously impede performance but more on that later.
    Acceleration is the time it takes to go from stopped up to the velocity speed or from that speed back down to zero, shown as the angled lines in the graph, .1 is a good accel but since your system is such a slug give it .5 seconds.
    Have you figured out the steps per and driver switch settings?
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Sep 2014
    286
    No mate, thanks for your help also, you seem to be the master at this
    I have 2 Nema 23 High torque steppers and one Nema 34.
    The ball screws are the standard 5mm pitch.
    I have purchased the ball screws from the same place I ordered the brackets. I assume they are made for each other. Automation technology.
    M542 for the Nema 34 and the M335 for the Nema 23. I need to know the dip switch settings so it is accurate and nicely smooth
    Cheers,
    Olly
Page 1 of 28 12311
  1. Yay! "Project Cecil" G0704 build has begun!
    By TroyO in forum Benchtop Machines
    Last Post: 03-31-2015, 09:29 PM
  2. Let's call this the Turnkey Project - G0704
    By bogiestl in forum Benchtop Machines
    Last Post: 01-30-2012, 08:11 AM
  3. g0704 - conversion project
    By dsdmax in forum Benchtop Machines
    Last Post: 03-02-2011, 04:03 AM
  4. g0704 - first mill - questions ....
    Last Post: 03-28-2010, 09:32 PM
  5. CNC milling machine project, Weiss WMD25 / Amadeal AMA25LV
    By carl0s in forum Uncategorised MetalWorking Machines
    Last Post: 02-20-2010, 12:47 AM
