587,328 active members*
3,346 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > Alarm 20 NMI emergency stop and alarm 204 spindle controller malfunction
Results 1 to 6 of 6
    Mar 2009
    36
    Exclamation Alarm 20 NMI emergency stop and alarm 204 spindle controller malfunction
    Hi
    I have a 1986 QT20N with Mazatrol T2 got from a auction with a spindle problem.
    On gear 1 machine get to 900 rpm but brake to 0 rpm is taking over 6 seconds. Acceleration to rpm's is ok.
    On gear 2 machine get to 2200 rpm but deceleration to 0 rpm is taking over 10 second. Even so! When machine is braking in gear 2 never manage to stop. I get Alarm 20 NMI emergency stop and Alarm 204 Spindle controller malfunction. Alarms are disappearing after shutdown an main braker in OFF position for couple seconds.
    I don't think it's normally for the machine to take so long to stop the spindle. I've seen some videos on YouTube and there was a much faster deceleration.
    It is reasonable to suspect that Alarms 20 and 204 have same cause?
    Anybody faced this issue?
    Mar 2009
    36
    Re: Alarm 20 NMI emergency stop and alarm 204 spindle controller malfunction
    Are there any brake resistors in this machine? Maybe are burned or disconnected. I don't know where to look.
    Mar 2009
    36
    I attached a video with this behavior. Any advice please?
    https://youtu.be/2maS3xcPl6I
    Sep 2017
    139
    Please share the alarm occuring on the spindle drive unit as well. also mention the drive unit model
    Mar 2009
    36
    Hi. Thanks for reply. It is a Fanuc a20b-1000-0693 controller. And I get Alarm no 2.
    Trimis de pe al meu SM-J530F folosind Tapatalk
    Sep 2017
    139
    Sorry I have no idea about Fanuc controller with Mitsubishi drives
  1. ALARM 20 NMI EMERGENCY STOP.
    By GPena in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-13-2022, 02:48 PM
  2. NMI 20 Emergency Stop Alarm
    By pcreek in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-17-2019, 01:52 PM
  3. Nmi emergency stop alarm
    By richalex in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-06-2015, 05:43 PM
  4. Alarm 128 QT-8 Emergency stop
    By grabolo in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-22-2009, 07:24 PM
