588,190 active members*
4,290 visitors online*
Results 1 to 2 of 2
    Mar 2008
    33
    Adding to a Romaxx cnc...
    I'd like to get into 5/6 axis machining of small wooden toys. I really like the Romaxx CNC 3 axis machine. It's just about the right size for what I want to do.
    My question for y'all out there: Can I add onto the Romaxx machine easily enough by buying additional drive units from http://www.doughtydrive.com/ and controlling these extra axes with a separate control box? The Romaxx machine says that it is ready to plug right into a PC, so they must have built a 3 axis control board into the machine. Therefore, I'd have to supply a separate 3 axis control enclosure for the A-B-C axes. I'm pretty sure that Mach-3 can control 6 total axes.
    If that is the thing to do, how do I connect both the Romaxx machine AND this extra drive enclosure to my PC? Thanks in advance for any advice!
    Jul 2006
    122
    You can build a 2nd 3 axis controller & run it on MACH3 as LPT2.
    You will need a good LPT2 port card that will put out 5VDC, some don't.
    You may want to check your Z axis height as I don't think it will fit in the space.
    Skip20
    Knoxville
  1. Romaxx
    By lovebugjunkie in forum Commercial CNC Wood Routers
    Last Post: 08-24-2022, 03:45 AM
  2. adding a longer bed
    By balsaman in forum Mini Lathe
    Last Post: 07-03-2021, 11:36 AM
  3. Adding a fan to the X3
    By Antonyong in forum Benchtop Machines
    Last Post: 04-26-2007, 05:19 AM
  4. Adding a Joystick.
    By on7tim7 in forum Mach Mill
    Last Post: 01-10-2006, 08:33 PM
  5. Adding a 4th
    By Shizzlemah in forum Fadal
    Last Post: 12-02-2005, 12:16 AM
