587,466 active members*
3,049 visitors online*
Results 1 to 20 of 30
    May 2006
    309
    Milling spheres?
    Have anybody here created a perfect round sphere by using the sphere code generator in order to create a half sphere first and then turn it around for completing the work? And are the ball mills that are for sale on ebay good enough for this purpose or do I need a perfectly grinded ball mill?
    Jun 2015
    4156
    Re: Milling spheres?
    hi jaru-eri
    this perfection depends on cnc accuracy ( available & output ) and backlash management
    even if you have a pretty accurate cnc, you should still consider to control :
    ... axis reversal ( near the top of the sphere )
    ... accuracy value
    example of backlash management functions, for okuma :
    ... ( variable ) lost motion compensation
    ... pitch error compensation
    ... reversal spike auto-adjustment
    example of accuracy control, for okuma :
    ... in-position parameter
    ... nurbs
    ... allowable errors in radius comp & in circular interpolation
    ... acceleration / deceleration
    also, a complex shape requires moderate feedrates, because higher values will lead to deviations
    i am afraid that you won't obtain a nice sphere if you go like that
    pls check video shared in this post :
    ... roughing is done on each half
    ... part is rotated with 90*, and roughing is repeated
    ... if you wish, you may repeat the process also at 45 90+45 180+45 and 270+45 degrees
    ... part is rotating during the pre-finish and the finish operations
    obviously, turning seems to be more indicated, or at least a vmc with 4th axis
    do you wish to know how balls of bearings are turned ? there is an insert for hard turning, and the ball is between 2 centers with spherical surface; in the end, the ball is reclamped in a rotated position, so to turn the material that was making contact with those spherical centers at the previous operation
    if you wish only to experiment, you don't need expensive tools no ....
    all you need is to adjust the cutting specs : for example, if you clamp a tool and it has 0.04tir, simply don't use a finishing feed > 0.04 / does it makes sense ? consider feed=60%tir; if you go like that, you should end up with a nice smooth surface
    if the surface is smooth, uniform, than measure spherical tolerance, so to see how close you are to a sphere : in this moment, if you are not satisfied, repeat the process with a higher quality tool ( from better carbide, with better coating and with better goemetry ), and clamp that tool with less tir : now you should see better results
    kindly
    https://www.youtube.com/watch?time_c...&v=NwOtZnjqKGA
    May 2006
    309
    Ok. I understand. But with all that difficulties, maybe it will be an easier and better choice to make the sphere in a manual lathe with a rounding tool instead?
    Dec 2013
    5716
    Quote Originally Posted by jaru-eri View Post
    Using a lathe with a radius turning tool might be the best choice. A CNC lathe makes it very easy.
    Jim Dawson
    Sandy, Oregon, USA
    Jun 2015
    4156
    hello again jaru those are not dificulties, but cnc related stuff when machining a sphere
    pls try not to look at them like being dificulties, and give up, so to chose a classical lathe
    classic and cnc have a lot of things in common
    about classic : you may also consider a copy lathe, or a dedicated holder, like jim dawson said
    about cnc : is pretty easy to turn a sphere; just go and try / kindly
    Quote Originally Posted by deadlykitten View Post
    hi jaru-eri
    ... accuracy value
    ... nurbs
    kindly
    Hey deadly kitten I’m currently undergoing this task in work.
    Attempting to turn a sphere on a cnc lathe. The video you’ve attached doesn’t work any more; do you know of a similar video or know where I can access this video.
    We’re having trouble holding the sphere for the 2nd operation.
    Thank you in advance.
    Kind regards,
    Bradley.
    Apr 2004
    5747
    [QUOTE
    [/QUOTE]
    That's always going to be a problem if you really need a complete sphere, not just a sphere on a stick. You either have to make a fixture that will hold the spherical part -
    like 2 plates with spherical divots opposite one another that you can clamp together and hold onto so that the stub end sticks out for machining - or do something like the procedure outlined above for making ball bearings.
    Andrew Werby
    Website
    Jun 2015
    4156
    hi, i just checked, and that video had been removed; it was about milling a sphere ...
    pls develop ...
    i suppose you turned a part of that sphere in 1st operation, and now you wish to finish it, and the 2nd operation does not has a good fixture ? maybe you can share an image with the sphere after 1st operation, and the clamping of the 2nd operation / kindly
    15362
    do you wish to know how balls of bearings are turned ? there is an insert for hard turning, and the ball is between 2 centers with spherical surface; in the end, the ball is decamped in a rotated position, so to turn the material that was making contact with those spherical centers at the previous operation
    That is total BS
    Balls for Bearings are cold headed into a rough ball shape and then they are rough cleaned up, then heat treated they are then ground, then lapped to finial finish and size, they are never turned in any way here is two snips of roughly how ball bearings are made
    Mactec54
    Jun 2015
    4156
    That is total BS
    hy mactec, technology for crafting the ball is not unique for the entire size range; frequent sizes are smaller, so there is justified a punch-forming machine
    also, what i have described is not a full process; what about cold/hot forging the ball + hard turning + grinding & sorting ( 2-3 baths ) + lapping ( 1-2 baths )
    maybe you should try a ball bearing ... kindly
    Dec 2013
    5716
    What size sphere? What is perfect for you?
    We CNC one part that has a sphere on the end but has a stem to hang on to for the second op. In the first op you would have to cut about 60% - 70% of the sphere, then for the second op you would need a special collet or soft jaws that would form fit the sphere and be able to grab it over center to hang on to it.
    If you really need it to be ''perfect'' then you have to process it like a ball bearing with a special machine.
    Jim Dawson
    Sandy, Oregon, USA
    Dec 2008
    3126
    Do we blame Jim for mentioning "ball bearings" ?
    ....or the other 2 for arguing about something off topic ?
    No-one knows if it is a true sphere (size ?), or something like a towball...
    Kitty... keep it on topic, stop making it over complicated
    Jun 2015
    4156
    maybe is a towing hitch ....
    Thank you for all of your reply’s.
    I don’t have a picture at the moment because I’m not in the factory as it’s the weekend in the UK. But I do have a picture of something similar that I’ve found from another thread. (Which I will attach)
    I want to turn it to a tolerance of around 2 thousands. But I’d be happy with 5 thou all the way around or even more.
    However that isn’t my main aim at the moment, holding the work for the 2nd operation is my main concern.
    Quote Originally Posted by Jarith1993 View Post
    Here is the attached image. Of a slug that someone else has turned so far.
    And the ball im looking to make is a 30mm ball (a perfect sphere with no holes etc to attach a stem)
    I’ve seen a few videos of people rough lapping on machines following a chamfer and pressing process.
    But ideally I want to do this on the cnc.
    The cnc we have at the factory is a haas sl20 if you’re wondering.
    Attached Thumbnails Attached Thumbnails A64C6814-C52A-4D53-A3A5-21B2EA2807FF.jpg
    Dec 2013
    5716
    OK, that information gives us something to work with. 2 thou roundness tolerance and 30mm dia. I was thrown off by your use of the word ''perfect'', to me that means sub-micron precision.
    As I said above, do the first op at about 60-70% of the sphere, then make soft jaws that form fit the finished portion to hold for the second op. There is no way to do this in one operation. Your sl20 should be more than capable of doing this.
    Jim Dawson
    Sandy, Oregon, USA
    15362
    Just as Jim has said, make some soft jaws they only have to hold around 60% of the diameter , cut the waste off and then turn the rest of the ball
    Mactec54
    Sep 2014
    129
    Aug 2009
    1573
  1. Need machine spheres
    By jeremy0203 in forum Employment Opportunity
    Last Post: 10-30-2010, 09:55 PM
  2. Need g-code for 4 axis semi-spheres.
    By jaru-eri in forum Mach Software (ArtSoft software)
    Last Post: 04-30-2008, 02:49 AM
