588,354 active members*
7,589 visitors online*
Results 1 to 3 of 3
    Sep 2005
    140
    Speeds and Feeds
    Hi all
    Wondering what spindle speed and feed rate people are using to mill hdpe. My top speed is 4600 rpm on my cnc'd mini mill and I have some hdpe parts to cut, I played around with it some last night but not happy with results. Any help would be great!!
    Walt
    Jul 2005
    969
    whats hdpe?
    224
    Well it could be High Density PolyEthylene.
    If it's poly then you can run max spindle rpm.
    Adjust feedrate to where the cutting looks its best... just experiment with the value for a particular cut.
    The main thing is to keep a blast of cool air blowing at the cutter. More is better.
    Note:
    If you don't keep the PE chips as cool as possible they will get too sticky and then it melts into a glob.
    (Glob = technical term for "blob")
    Suggestion:
    Keep a ShopVac hose sucking up the chip stream helps keep the cutter visible -so you can see whats happening.
    Good luck,
    Pres
  1. Speeds & Feeds
    By hector herrera in forum Mastercam
    Last Post: 02-20-2007, 09:21 PM
  2. feeds and speeds
    By JpBinc in forum MetalWork Discussion
    Last Post: 10-03-2006, 06:48 AM
  3. feeds and speeds
    By rchprks in forum MetalWork Discussion
    Last Post: 07-18-2006, 12:48 AM
  4. Speeds and feeds
    By Hack in forum MetalWork Discussion
    Last Post: 10-15-2005, 04:47 PM
  5. feeds and speeds
    By lito in forum MetalWork Discussion
    Last Post: 03-14-2005, 02:58 PM
