587,771 active members*
3,031 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > V22 Boolean Subtract
Results 1 to 13 of 13
    May 2006
    150
    Guys, please help me to subtract an area from a large surface. I've imported, then extruded a shape to get a solid. Now, I'd like to remove a ovalized square.
    The software changes the color of that area and adds a curve under one of the corners. The part has another feature (hole) to be removed. That was easy and it took just a few seconds.
    What am I doing wrong?
    TIA!
    Rob in Ohio
    May 2008
    5
    Pick the solid that you want to keep first, then select the solid you want to remove. Right click. Select ok. Boolean operation should then execute.
    May 2006
    150
    I can't get the area to extrude. That's the problem that I'm having.
    Rob in Ohio
    Nov 2008
    14
    Hello,
    I am new to the cadcam software world and I have v21 bobcad. I have been playing with it,b ut there are some pretty remedial(to someone who knows the software)questions I have. Would anyone be willing to help with ofsetting my learning curve?
    Nov 2008
    14
    First I'm cutting a hex shaped part and I was wondering if there was a way to draw a hex without drawing each individual line. Second, I want to machine that hex leaving stock for a second pass(in x and y axes only), do I simply offset the geometry by my desired second pass amount and then cut all on both?
    Jul 2006
    66
    Hex.bas
    If you know how to use the scripts, here ia a hex.bas to use
    'HexFlat.bas
    UnselectAll
    R=2.0*25.4
    Ask Header="Hexagon by Flats",Output,Cancel=canc,\
    "Distance Across Flats"=R
    If canc=1 Then
    Exit
    Endif
    R=R/1.732049
    I=R*COS(1.0471976)
    J=R*SIN(1.0471976)
    PointCoordinates X = R, Y = 0, Z = 0
    PointCoordinates X = I, Y = J, Z = 0
    PointCoordinates X =-I, Y = J, Z = 0
    PointCoordinates X =-R, Y = 0, Z = 0
    PointCoordinates X =-I, Y =-J, Z = 0
    PointCoordinates X = I, Y =-J, Z = 0
    Close
    LineJoin
    ViewAll
    Mark
    "I'll keep my gun, my ammo, my money, my freedom and you can keep the "CHANGE" !
    Apr 2008
    1577
    Quote Originally Posted by turningman33 View Post
    Aside from the excellent script Swap posted, there are other ways. For a hex that measures 1" across the flats, you could draw one line at, say:
    X0.5 Y-0.25
    X0.5 Y0.25
    Now select that little line (if it's not already selected) and go to "Change, Rotate". Set the coordinate rotation to X0 Y0 and the angle around the axis Z to 60 degrees. Check the box for "Make a copy" and make 5 copies. Click OK and you should have 6 unconnected lines.
    If they aren't already selected, select each line making sure the direction of the arrows are all going in one direction ( I prefer counter clockwise, no reason ). Now go to your "Special - NC" menu item and click "Close". Nothing will happen, we are just setting up for the final operation.
    Finally go to "Change, Trim and Extend, Strings". The software will automatically connect all the unconnected lines and they will be trimmed appropriately.
    OR
    Just use the script Swag posted
  1. Boolean Operation with a Mesh
    By chaddcurtis in forum Rhino 3D
    Last Post: 02-22-2011, 09:08 PM
  2. Boolean
    By camtd in forum Uncategorised CAD Discussion
    Last Post: 09-22-2008, 12:31 AM
  3. ADD - SUBTRACT 2 DIFFERENT PART ????
    By firefox66 in forum Solidworks
    Last Post: 03-23-2008, 02:49 AM
  4. Help - 3D subtract
    By NickAshton in forum Uncategorised CAM Discussion
    Last Post: 01-14-2008, 11:42 PM
  5. Boolean Feature
    By svenakela in forum Uncategorised CAD Discussion
    Last Post: 08-28-2007, 03:18 AM
