588,529 active members*
6,390 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Water Jet or Fiber Laser Jet Laser Markable AL Sheet
Results 1 to 2 of 2
    Oct 2011
    12
    Aluminum Legend Cutting Process - Looking for a best cost effective solution to cut blanks and cut holes into the flat blanks of Aluminum sheet per these features:
    Material - 0.020” thick aluminum laser markable (black anodined surface), has adhesive backer - Johnson Plastics AM5975
    We normally buy/use a plastic sheet from them to laser the whole pieces but this is a different application needing aluminum.
    Designs:
    1. Blanks - have have a 9-10 shapes but for example a 3" x 10" rectangle with corner radii - geometry from AutoCAD file
    2. Holes to be in Blanks - several holes and slots are cut into the blanks for toggle swtiches, push buttons, etc. - this configuration changes per order - geometry from AutoCAD file
    3. Laser Engrave Text by Holes - We place the machined legends in our bench top laser engraver to run the order's text program
    Our Current Cumbersome Process - We CNC mill the holes and then the outer profile from a retangle blank sheet. We then place the cut profile onto our laser engraver into a legend with corresponding cutouts to locate on the bed for lasering the text from an AutoCAD file.
    Volume - it is lower volume – approx.. 4-20/day.
    If need be I could buy blanks for the standard blanks we use to get away from that at least.
    Place blanks into a recessed pocket and tape the blank down to hold it. CNC the holes like today.
    Other options like lower cost fiber lasering or water jet cutting the blanks and the holes? Or other methods with our CNC mill?
    Brad
    Feb 2009
    6028
    .02 aluminum is not that hard to laser cut. You should be able to laser the shape and do the text in one shot. You REALLY don't want to deal with a waterjet for that small of QTY. Waterjets are expensive to run and maintain, and they are nasty dirty little buggers.
  1. Water Jet or Fiber Laser Jet Laser Markable AL Sheet
    By BradS. in forum Waterjet General Topics
    Last Post: 05-17-2013, 09:36 PM
  2. Water Jet or Fiber Laser Jet Laser Markable AL Sheet
    By BradS. in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-14-2013, 11:00 PM
  3. pulsed fiber laser cutting silver sheet
    By dcas1 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-16-2011, 05:53 PM
  4. Replies: 1
    Last Post: 01-14-2011, 04:43 AM
  5. Laser + carbon fiber = ??
    By theclive in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-29-2007, 12:04 AM
