588,227 active members*
4,811 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > BOB and NPN Proxy Switch wiring question.
Results 1 to 20 of 20
    Dec 2005
    258
    I'm using LJ12A3-4-Z/BX NPN 3 wire Proxy Switches for my new Avid CNC 4848.
    The Proxy Switch signal wire (on 12v source) puts out 12v constant and when triggered drops to 0.68v,
    My BOB has 4 external inputs (estop,limits etc) that set at 5v (high) so I assume I need to ground these when the limit switch is triggered.
    How do I get the proxy switch to ground the 5v and how do I protect the BOB from the 12v input when it's not triggered?
    TIA
    Mar 2007
    2083
    Re: BOB and NPN Proxy Switch wiring question.
    if the LJ12A3-4-Z/BX NPN 3 wire Proxy Switches output switches between 12V & 0.68V
    they are not open collector NPN outputs as I would of expected
    and must have a pullup resistance between the output & the +12V supply
    ( do the switches have a LED indicator between the + supply and output ? )
    details of the machines BOB would help
    I would try using a Schottky Diode to connect the Proxy Switches output to the BOB input
    by connecting the cathode (with the band ) to the switch output and the anode to the BOB input
    the forward voltdrop of a Schottky Diode is about 150–450 mV. ( instead of 600–700 mV, for a silicon diode )
    this will pull the BOB input closer to ground for a valid logic 0 but block current flowing from the +12V and into the BOB input
    example wire ended Schottky Diode
    STMicroelectronics 70V 15mA, Schottky Diode, 2-Pin DO-35 1N5711
    RS Stock No. 168-6622
    https://uk.rs-online.com/web/p/produ...YAmQ&gclsrc=ds
    I'm assuming the BOB input is either a 74 series TTL input or Cmos input with a pull down resistor to ground
    john
    Dec 2005
    258
    Switches I'm using:
    https://www.ebay.com/itm/5Pcs-LJ12A3...72.m2749.l2649
    The have a typical LED that lights up when metal is detected, not sure if it's between the 12v+ and Output wire.
    The BOB seem great but is hard to find anything in depth on, best info I have is here.
    https://www.instructables.com/id/6-A...terface-Break/
    https://www.amazon.com/gp/product/B07PSJF5HN
    BOB IC:
    74HC14
    Got the Diods in my shopping cart, suggestions for pull up resistor/s for 19v source for Proxy switch power?
    Thanks John
    Jan 2010
    77
    You could use a relay board like this and from the contacts of the relays, just apply ground to the board input when it's active. https://www.ebay.com/itm/4-Channel-1...53.m2749.l2649
    Mar 2007
    2083
    looking at the picture of the BOB
    the inputs have opto-isolators its possible the resistors that limits the LED current when the input is grounded
    are connected to a +12V supply and thats what you measured when the switch is off
    Attachment 426320
    the resistor may be about 1K (1000 ohms) which would limit the LED current to about 10mA when the BOB input is grounded
    If I am correct
    seeing more that 5V at the BOB input terminal is not a problem even though the 74HC14 IC is powered by a 5V supply
    possible opto -isolator used ? PC817
    data sheet
    Attachment 426322
    John
    Dec 2005
    258
    At the moment I am using my 12v lab PSU for testing the proxy switches wired only/directly. BOB is installed on the machine and has not be tested along with.
    Each input pin: has 5v power, has a resistor with 511 on it (think I measured .540ohms across each one) and they are all protected with an opto then to another resistor on the back side.
    I didn't think I needed a resistor for the proxy switches because it was active high and then goes low when the switch is flagged. I was thinking a resistor for reducing the voltage on the output/signal (black) wire to protect the BOB. Which if your correct would be great to not need.
    NOTE:
    I have read these Proxy switches will actually function off 5v. (i will give this a try today) Would that make things simplier?
    Beside the high level of input signal (12v), theoretically - when the proxy switch is flagged and drops to O.68v would that pull the active high 5v input pin/s to ground or 0V triggering a 0 or false to mach3?
    I have attached a close up of the BOB with the Optos in view.
    Always appreciative of the help.
    Eric
    Mar 2007
    2083
    OK
    so the LJ12A3-4-Z/BX NPN 3 wire Proxy Switches output switches between the 12V supply and 0.68V without a connection to the BOB
    on the breakout board
    the opto-isolator is just another manufacturers version of the PC817 from panasonic I expected
    the resistor on the board that limits the LED current is 510 ohms ( marked 511)
    what voltage do you measure between the BOB's input opto isolator pin 1 and the limit switch common / ground ?
    Attachment 426328
    if the opto-isolator pin 1 was at +12V
    you can connect the BOB's input to a Proxy Switches output run from 12V
    and you connected a Proxy Switch connected to a 24V supply
    I would add a diode to stop the BOB's input being pulled higher than 12V that would result in the LED being reverse biased
    John
    Dec 2005
    258
    I have 5v at pin1 using the Input common ground.
    I also tested the Proxy Switch from the BOB Input 5v & Common GND and it does trigger from about the exact same distance as when on 12v.
    In this case as you might guess the Proxy switch is 5v until flagged in which then it drops to 0.61v.
    Thoughts?
    TIA
    Eric
    Mar 2007
    2083
    that internal diagram of the LJ12A3-4-Z/BX NPN 3 wire Proxy Switch explains a lot
    and confirms there is a pullup resistor to the switches positive supply
    this is what I had before you posted the details
Name:	proximity switch and BOB.jpg
    so you either can power the Proxy Switch from 5V
    or add the diode to protect the BOB input from being taken over +5V
    ( the reverse brake down voltage is only a few volts and depends on the LED colour)
    in the case of the EL817 opto isolator the maximum reverse voltage is 6V
    John
    Dec 2005
    258
    I don't have your electrical wits but looking your your top diag, do you see any reason I can not just wire Brown+ to +5v Input, Blue- to Input common GND and Signal wire to one of the Input pins (active high +5v)?
    If I just wire it straight forward will the Proximity switch pull BoBs Input Pin/s +5v to ground and give me a valid logic of 0 for Mach3?
    Eric
    Mar 2007
    2083
    yes
    if the Proximity switch works when connected to a 5V supply ( instead of 6 to 24V )
    then connecting the brown wire to the BOBs +5V
    Blue- to Input common GND and Black Signal wire to the BOB Input
    outwill work
    found this on line indicating it has a NPN Normally Open output
    Attachment 426338
    which makes it acive low
    John
    Dec 2005
    258
    Do I just wire my Estop to limit common ground and to the 5v high input pin?
    Thanks John, you're a life saver.
    Eric
    Jul 2017
    57
    Just curious,
    Are you using a motion controller with this? I thought cncrouterparts included electronics with their routers.
    Apr 2003
    540
    I had issues with NPN proximity switches also. Might have simply been the make/model or specs of mine, but between pull down resistors required etc was just a hassle. As another posted above I used a simple multi channel relay board. It was very easy to hook up and has worked flawlessly.
    Mar 2007
    2083
    Hi Eric
    I missed post 12
    yes
    just connect the E-Stop between the input common and the input pin (15 ?)
    I would use the N/C terminals and set the switch as active high
    that way a broken wire triggers an E-Stop
    John
    Dec 2005
    258
    Will do.
    If I understand correctly, the Proximity switch setup I am going with will be fail safe in the same way since its active high correct?
    Mar 2007
    2083
    Going by the info I found and attached to post 11
    the Proximity switches are normally open (N/O)
    ( the limit switch needs to be set as active low )
    So they would fail to work if a wire went open circuit
    which is very often what happens when wires are repeatable flexed
    John
    Dec 2005
    258
    Is this why...
    The Limit switch always provides 5v until it is flagged.
    So If the wire breaks (because the BoB already provides a high 5v) there is nothing to bring the input to 0v so there is no logic signal sent?
    But if the board didn't supply 5v and had to get it from the PSwitch sginal wire - then if the wire broke it would drop the voltage, signalling a logical machine stop?
    There's not an alternative way to wire the PSwitch without involving relays, such as polarity swapping BoB hack or something right?
    Mar 2007
    2083
    yes
    looking at the internal circuit of the Proxy Switch from an earlier post ( #8 )
    Attachment 426514
    the 10K resistor pulls the output up to the +5V supply when the switch is open
    once tripped, the switch closes and grounds the output
    ( the NPN transistor switches on and the output goes down to 0.68V )
    John
    Dec 2005
    258
    Appreciate all your help John.
    Only my Z Proximity switch wiring moves via wire chain the other axis wiring are statically installed.
    I am hopeful this will greatly reduce the chance of wire break. I still rather have a NC setup.
    Eric
  1. Wiring New Limit Switch, Wire Color Question
    By JMFabrications in forum Haas Mills
    Last Post: 03-22-2014, 06:02 PM
  2. Another sPID, G540, and Mach wiring question for the wiring challenged..
    By adam_m in forum DIY CNC Router Table Machines
    Last Post: 01-02-2014, 01:29 AM
  3. Mechanical Vs. Inductance Limit & Proxy switches
    By crane550 in forum DIY CNC Router Table Machines
    Last Post: 03-07-2012, 04:21 AM
  4. simple micro limit switch wiring question
    By nateman_doo in forum Benchtop Machines
    Last Post: 12-18-2010, 11:24 PM
