588,227 active members*
4,386 visitors online*
Results 1 to 19 of 19
    Sep 2012
    117
    Help ! breaking bits
    Why are we breaking bits?
    6061 T6, full flood coolant 5000 rpm
    Bits .25" Dia / 1.75 Loc -Interstate and Hertel 2 flute 37dg HSS/HSS-Tin
    Depth .05 / 10 ipm went to 7 ipm still breaks , chips are tiny
    25% stepover
    program run time 11 hours @10ipm
    bits are losing their edges before breaking, cut is super smooth for the first5-6 hours, then it seems they loose an edge .
    What do we need to change?
    UPDATE
    Thanks, for the replies!
    Looks like we will be using a 3/8 bit for most of the roughing, that will cut the run time as well.
    We were hoping to stay away from a tool change, as we need to run this overnight, more labor intensive operations during the day.
    May 2004
    4519
    As a starting point - Switch to carbide. SFM - 450. RPM 6876 for 0.250 Dia. 27.5 IPM for 2 flute. 0.2 axle DOC. 0.2 radial DOC.
    Feb 2006
    7063
    Quote Originally Posted by txcncman View Post
    0.2" DOC/27.5 IPM with a 1.75" long 1/4" endmill? I don't think so. He wouldn't make it even one inch.
    With such a long tool, you'll need to go VERY shallow, as the tool will be deflecting a LOT, which is certainly what's killing it. But you indicate it cuts fine for 5-6 hours, then the edges go dull, and the tool breaks. So why aren't you changing tools BEFORE they go dull, if it's working OK up to that point? 5-6 hours is probably pretty good life for a tool working under such difficult conditions. A dull edge will dramatically increase deflection. If you're really getting a good result for those first 5-6 hours, I would swap out the tool every 4 hours.
    Overall, you'd be better off finding a way to do it with a larger diameter tool. And carbide is likely to help, as it's much stiffer. But, at the same time, it may well dull, or even break, much sooner, as it's so much more brittle, and much more easily damaged than HSS.
    Regards,
    Ray L.
    May 2004
    4519
    Actually I meant 0.1 axle DOC and 0.1 radial DOC. Sorry.
    May 2004
    4519
    For the carbide mentioned above with 5000 RPM maximum, change the feed to 20 IPM.
    Feb 2006
    7063
    Even that is very aggressive for such a looooong tool, and I assume he HAS to be cutting full-width a good portion of the time to clear the spaces between those bosses.
    Regards,
    Ray L.
    Jan 2012
    714
    What is the actual depth of the cut in the part?
    Is a cutter that long needed for your operation?
    mike sr
    Sep 2012
    117
    We are maxed out at 5K rpm
    Sep 2012
    117
    update in OP
    Feb 2011
    605
    - What is the order of operations?
    - Is that a single part, or a bunch of the same part?
    - What is the spacing between the bosses?
    PM-45 CNC conversion built/run/sold.
    Jun 2006
    2512
    Tiny chips would normally indicate to lower feed rate which could mean you are simply wearing out the cutting edge. If it cuts fine for the first 5 hours maybe you should experiment with a higher feed rate. Of course as Ray points out the tool length may be a limiting factor preventing higher feed rates. Best way to find out is try it.
    Phil
    Jun 2005
    1015
    break it up into two tools. use a shorter endmill do the top portion and get it done alot quicker, the switch to the long reach end mill and finish the bottom half.
    or
    use a drill bit and drill out the majority of the periferal material and then use and end mill to finish. again if you use two end mills then the shorter end mill can use more aggressive speeds and feeds and then only use the long for areas you can't reach and for finish passes.
    option 2 doesn't seem elegant but working in a home shop its probably your best bet.
    Jan 2012
    789
    Rules of thumb-
    Use the biggest diameter tool you can.
    Use the shortest tool you can. Those two let you:
    Run the bit fairly hard, which keeps down rubbing.
    But I would really consider switching to a carbide for your 1/4". I don't have any chipping issues, and the stiffness will give you a much better finish.
    Jun 2006
    3063
    Though that looks like a fairly stiff chunk of aluminum, could part of the problem be due to the part overhang on the sides of the vises?
    Whenever I attempt cuts on parts like that I get a lot of chatter, essentially all of it from the part vibrating while cutting away from the vise.
    Perhaps 2 vises to hold the workpiece would help.
    Mike
    Mar 2009
    1863
    To cut between the webs, I would never use a linear move for that type of cut. I would develop a hole pattern and plunge the material out to ruff it, then make a program to finish it. I would probably make a program using 2 cutters, and I would throw the HSS stuff in the garbage and use only carbide.
    You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
    Jan 2007
    243
    Try 3/8 3 Flute MicroGrain Carbide endmills from Fullerton Tool. I used them extensively in my RC parts business. Worked great!
    www.WebMachinist.Net
    The Ultimate Online Source for Machinist Related Stuff!
    Dec 2006
    302
    Steve is absolutely right. Last summer I made an AR lower (on my knee mill). The material was 7075 and required much relatively deep pocketing. I rough drilled to remove as much metal as safely possible, then finished with 3 flute carbide end mills, minimum possible stick-out. No problems.
    John
    Sep 2012
    117
    Thanks for the replies , we will have to learn the plunge cutting method you guys are doing, sounds like that would be MUCH faster as well.
    So are you using s drill bit for the ruffing?
    Haven't been here for a while , too much stuff needing done.
    Mar 2009
    1863
    If you are going to plunge ruff a pocket, I would seill a hole the soze of your end mill first, then finish your plunge ruff with your end mill taking cuts about 35% of the diameter of your cutter.I.E 3/8 diameter cutter, .130 to .15 wide cut and feed down at 30 to 50 IPM debending on the depth of your cut.
    Make your program by creating a drilling routine and use either G81 or G83, again depending on the depth of your pocket/slot.
  1. Breaking bits
    By Ansen in forum Glass, Plastic and Stone
    Last Post: 10-10-2012, 10:44 PM
  2. Breaking 1mm bits...
    By billturnbull in forum CNC Tooling
    Last Post: 07-19-2011, 02:39 PM
  3. I Keep Breaking 1mm bits
    By Cosha in forum CNC Tooling
    Last Post: 06-14-2009, 10:01 AM
  4. Breaking Bits Help
    By ninewgt in forum Composites, Exotic Metals etc
    Last Post: 04-01-2005, 02:23 AM
  5. i keep on breaking bits???
    By joeyboy in forum Uncategorised MetalWorking Machines
    Last Post: 03-24-2004, 10:18 AM
