587,143 active members*
5,379 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > OKUMA OSP7000 reload datas procedure
Page 1 of 2 12
Results 1 to 20 of 25
    Jan 2013
    7
    Lathe machine LCS15E with OSP7000 has lost datas due to battery backup drop off.
    At power on alarm 945 appear.
    If i turn on maintenance switch on CNC i can see the menu to reload software data.
    I have 6 floppy disk with all original backup.
    Could someone explain the step-step procedure to reload it?
    Machine is provided with Floppy Disk Drive.
    Thanx for your support.
    Roberto
    Feb 2009
    6028
    turn on load switch
    put disk 1 in
    press load start
    follow prompts
    Jan 2013
    7
    i tryed to do so, but it says that install file not present.
    If i try to read disk#1 #2 in my PC they look unformatted.....is it correct?
    Feb 2009
    6028
    They will not read in a PC.
    I vaguely remember needing a system install disk, been too long, but i thought disk 1 was the install disk.
    Mar 2009
    1982
    the 1st disk is Okuma bootable. It could be incompatible with MSDOS. The installation set is provided by Okuma, can't be made by Okuma backup. Most of disks are OSP format. All installation set is one continuous product.
    Aug 2012
    164
    Depends on the version of software you have - there were two types on the 7000L - the older type had disks labeled "FR 1/n", where "n" is the number of disks in the set. With this set, you will also have a disk labeled "MD 1/1". On the newer type of software, there is a set of disks, but the easy identifier here is that the first disk in the group will be labeled "INSTALL FLOPPY" and it will be red in color. Let me know what you have and I'll get you the procedure.
    Dec 2011
    8
    Re: OKUMA OSP7000 reload datas procedure
    Quote Originally Posted by cncts11 View Post
    Hi sir......
    I would like to disturb you,I also met one similar case and I've run Disk 1/8 (red disc), I get the message as images 1 and
    when I run disk 2/8, I get error messages such as picture number 2
    -please tell me what should I do in this case?
    look forward to your help .... sincerely appreciate very much
    Dec 2020
    4
    Quote Originally Posted by mrphuocauto View Post
    Hi sir......
    a mi me paso lo mismo error y era la tarjeta SVP la cambie y corrió el sistema pero ahora arroja la alarma de baterías y carga de software, compre el software y no puedo instalarlo, si pudo resolver su problema agradecería su ayuda.
    Quote Originally Posted by julio88 View Post
    Hola a todos, por favor ayúdenme. Gracias. Okuma osp7000l El programa del dispositivo ha sido eliminado y se puede ver este error (foto número uno) Y la luz de control sber está encendida, luego traté de instalar el programa e ingresé el disquete uno. Después de seleccionar la opción paquete e instalación personalizada, encontré un error de foto número dos. ¿Los disquetes tienen algún problema? ¿Cómo instalar el programa equivocado? ¿Problemas con los tableros de control? También reemplazamos la placa fpt con la placa de control, pero el problema no se resolvió
    ¿Se resolvió su problema reemplazando la placa svp y también se le encendió la luz de control sber? Gracias por su ayuda.
    Apr 2014
    5
    Hello, i have the same problem with one of my LU15-OSP7000L. Battery was changed 2011, no other messages and one morning it didn't wake up :/
    I have all the system disks and i did the install procedure. Problem is now i still get the "Battery Dead" alarm and machine boot up doesn't continue.
    Could you advice if this is normal or i did something wrong ?
    Can anyone send me an image (.ody made with OSP Floppy Okuyucu program) of the Battery Change and Backup (Disk D i think) diskette so i can make a backup and reset my alarm ?
    Thank you in advance.
    Aug 2012
    164
    I assume you are getting the 4035 Battery/Memory Board Alarm; the only way to get rid of that is with the use of a utility disk. There are actually two disks that can do this, of which neither were given out to customers. The first disk is the Battery Initialization Disk, the second is a new utility disk (commonly referred to as the maintenance disk) that contains a bootup menu essentially the same as what is on the U10/U100 and newer controls. This menu has various options, one of them being the restoration of the battery. Most of the dealers use the new maintenance disk. I don't know if the dealers will sell it to you, but they have it and can reset that alarm.
    Apr 2014
    5
    Yes it was that alarm.
    Anyway i somehow found the OSP7000 System disk (i guess it's the utility disk) i reset the alarm and the machine boots up.
    Now it brings up alarm that parameters are missing. I have a diskette which contains the A.top and all other PBU's etc. I follow the procedure but when i try to copy the parameters in the machine i have 2 problems.
    According the procedure i must copy all the files in MD1: first, when i start copy i get message that memory is full at half of the list.
    When i try to read the A.TOP file directly i get error message that the "Decimal point unexpected" or sort of ... any ideas ?
    Aug 2012
    164
    After you load all the software, you should cycle the power and bring the machine up in normal mode, with e-stop in. When you bring the A.TOP file back in, all you need to do is go to EDIT AUX, find DATA PIP and then select "input", type "FD0:" and hit the write key. It should bring all the data in. If the A.TOP file was made in inch, you may have a problem; that file should be made in metric mode, as the control may have a problem with the rounding of data, which would stop the loading process.
    Apr 2014
    5
    Everything up and running. Thank you for the support.
    The actual problem with the A.TOP was the emergency stop, i missed it the first time and it generated that error (strange that the error was for decimal point ...)
    Repeated the procedure with e-stop pressed and it went well. The okuma service guy who made the backup in 2011 didn't make the lower turret B.TOP but anyway i restored the limits and it's working.
    Now i have all the disks images copied on an usb stick so if everything happens with the disks in future i can create new ones.
    May 2016
    4
    Hi everyone;
    I was wondering if anyone has Okuma OSP7000 's six installation floppy disks. My disks arent working.
    Thanks everyone
    Golpar
    Apr 2014
    5
    Quote Originally Posted by Ajamimachinery View Post
    Hi everyone;
    Thanks everyone
    Golpar
    What model is the machine ? I have disks but they are for LU15/LU15M, don't know if parameters would work on your machine.
    Apr 2011
    112
    guys i have a problem on the instal part . I have change the ucmb and now it gives a 955 error has anyone had this problem ?
    0955 Spec. code: data file
    [Code] ABCCCCCC
    A:
    1-> NC specification code file (FR0A
    2-> EC specification code file (FR0A
    3-> NC specification code file for PLC created by MTB (FR0G
    4-> NC specification code file for PLC created by MTB (MD0G
    B:
    1-> No file is found.
    SECTION 3 ALARM P
    4187-E P-74-R2
    2-> File attribute and sector size do not conform to ’SPC1’.
    3-> Mismatch of the machine number
    3-> Mismatch of the machine name
    4-> Mismatch of the specification code data
    6= -
    7= Mismatch of the specification code data (such as machine number, machine name, and coded data)
    except for the data stored in the specification code change file
    8= The file is not OSP-formatted.
    9= File open error
    A= File read error
    CCCCCC: 000000 ... BÅÇ5
    XXYYZZ ... B=5
    XX: Byte position of the mismatched specification code
    YY: Mismatched specification code data
    ZZ: Specification code data (before change
    Apr 2011
    112
    the FR instal Meniu gives a 152 alarm
    152 Memory disk ROM write
    An error occurred in data writing onto the memory disk (FR).
    [Character-string]
    Start of writingThe transition from read-only mode to program mode does not take place.
    End of writing The transition from program mode to read-only mode does not take place.
    Verify Verification proved that the data written onto the memory disk (FR) did not match the original data.
    Element deleteElement in the memory disk cannot be deleted.
    Running task During task running, writing was attempted onto the memory disk (FR).
    [Code]
    1-> An error occurred in the memory board No. 1.
    2-> An error occurred in the memory board No. 2.
    XXXXXXXX->Address near the error location
    [Probable Faulty Locations]
    1) Defective memory disk (FR)
    2) Defective control software (in the case of task running)
    [Measures to Take]
    Change the memory board or flash memory card causing the error. * Correct the control software (in the case of
    task running).
    Dec 2020
    4
    buenas tardes!
    alguien que tenga el disquete de mantenimiento para cargar software a osp700l
    May 2017
    19
    buenas tardes!
    gracias por la respuesta. tenemos el disco de mantenimiento así como los discos de software.
    el problema es que el disco 8/10 no se carga
Page 1 of 2 12
  1. Okuma lb15 II-m OSP7000 IGF
    By Kholm3 in forum Okuma
    Last Post: 03-05-2014, 10:57 PM
  2. OKUMA OSP7000 LATHE
    By cbrannam in forum Post Processors for MC
    Last Post: 02-22-2013, 03:39 AM
  3. Replies: 31
    Last Post: 10-11-2011, 03:33 PM
  4. Okuma LB25II OSP7000 Wiring Diagrams
    By chenzen666 in forum Okuma
    Last Post: 08-11-2009, 11:16 PM
