588,597 active members*
11,232 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > Haas TL-1 tailstock reach with Auto Turret
Results 1 to 9 of 9
    Sep 2008
    17
    We have a new TL-1 with the auto turret and manual tailstock. We are turning some long small parts 0.5" in diameter and need to use a dead center on the tailstock. The problem is we can't find one that has the reach to clear the auto turret. The dead center needs to extend out of the tailstock by about 6"+.
    Can anyone help with a solution?
    Many thanks!
    Mar 2007
    32
    Are you sure you want a "dead center"? I think a live center would be a better choice. I have seen CNC centers that apear to have an extended reach. Probably not enough though.
    Sep 2008
    17
    At this point I would use a live center if I could find one with lots of reach.
    I call my Haas service center and they didn't have an answer. They are getting sales involved. My guess is they will try to sell me a manual tool post like they should have from the start. This is a terrible way to do business.
    Nov 2007
    1699
    Can you post a picture of the setup so we can see the problem?
    Greg
    Jul 2005
    12177
    Is it not possible to do things the other way around; extend the tool out from the toolpost so the tailstock barrel can come down past the turret. On half inch material you are not taking a big cut.
    Just remember to move well back before indexing the turret.
    Sep 2008
    17
    Geof -- many thanks
    This might work. I must extent the tool so that only two of the three screws can secure it. I will look for some long tools but I think this will work.
    Oct 2003
    352
    Use a #4 morse taper male x female extension. That would be the easiest way if a very long center is not an option.
  1. Lathe auto-turret project log
    By kong in forum Vertical Mill, Lathe Project Log
    Last Post: 05-28-2015, 06:45 PM
  2. Haas SL-30 Tailstock question
    By chrisryn in forum Haas Mills
    Last Post: 05-07-2008, 07:44 PM
  3. Lathe Auto Turret Design WIP
    By RedDog22 in forum Uncategorised MetalWorking Machines
    Last Post: 03-09-2008, 08:37 AM
  4. Turret Index Only Once In Auto
    By rajesh_1355 in forum Fanuc
    Last Post: 01-29-2007, 12:48 AM
