588,395 active members*
5,140 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > what type of paint to use on milling machine or lathe
Results 1 to 5 of 5
    Jan 2006
    48
    i can anyone tell me what is the best paint to use for a milling machine etc and what sort of preparation (? speling) do i need to do .....all the best derkiow
    Aug 2003
    8
    I went with a Duron Alkyd Paint (I believe it is made by DuPont). It
    is formulated to take the wear and tear of machine use and oil. I
    used it on my Milling machine when I rebuilt it and it really holds
    up well.
    Another paint to look into from a contact of mine is Magnet Paints,
    http://www.magnetpaints.com/
    4800 series for topcoat and the 300 series primer
    You can brush, roll, and spray these paints. I recommend thinning them down with the appropriate solvent and roll/brush them on. Spraying is a pain to clean up using these types of paints. I have had excellent results and they really do hold up to any chemical you throw at them. just make sure you get down to metal or sand the paint to score it. Make sure there is no rust.
    I am currently rebuilding my 10" Sheldon EXL Lathe and using the same paint. It's alot of work, but the finished product can't be beat.
    Jan 2006
    48
    thankyou for your suggestion......all the best derkiow
    Dec 2007
    98
    Re: what type of paint to use on milling machine or lathe
    Quote Originally Posted by derkiow View Post
    For metal objects I always use appliance epoxy, it comes in a rattle can and cost about five dollars here in the USA. Prepare and clean the surface as you would with any ordinary paint. It's only disadvantage is that it only comes in a few basic colors.
    Dec 2003
    24220
    Not sure if you can get it in the UK, but I have used Tremclad Rustoleom, it can be mixed to custom colours at main paint stores and has a rust prevention ingrediant.
    Al.
    Albert E.
  1. Replies: 2
    Last Post: 11-12-2013, 12:13 PM
  2. Replies: 0
    Last Post: 09-20-2013, 12:38 PM
  3. Face milling operation on Table type Horizontal Boring Machine
    By SatishNaik in forum News Announcements
    Last Post: 09-05-2013, 07:44 AM
  4. Replies: 0
    Last Post: 11-02-2009, 06:52 AM
  5. NK-WJ46 airless paint sprayer with air-driven type
    By paintsprayer in forum News Announcements
    Last Post: 08-04-2009, 04:32 AM
