588,386 active members*
5,160 visitors online*
    Jun 2010
    How to transfer files to 840D?
    Hi all,
    This should be a simple (maybe stupid) question. We have a special latch with 840D controller. We always manually insert program into the controller, but my boss asked me to find a way to transfer data from PC to the machine. I've opened the controller box and saw COM/Ethernet port. My question is, can we use network to transfer program files from PC into 840D? If yes, does it need additional Siemens module? What software is required in PC side?
    Thank you very much
    --A. Mandous
    Jun 2010
    46
    If the controller is a 840Di series then it would be windows based and I think most siemens are I think.
    The ethernet net is used for maintenance only
    If you connect the ethernet on a network then it can be infected by viruses / worms ect.
    My advice is not to
    There is a password to get on and it is well known this password and it will let you access all parts of the controller.
    Someone only has to make a little mistake and the controller will not work correctly.
    Personally just keep using the RS232 or USB.
    I believe there maybe some software but I'm told it is expensive
    There are several companies use eithernet for there machine but have discontinued there use due to Hacking as most users have them on a network which is connected to the ethernet.
    I have come across one case that a network kept alarming that they had a virus on a Fanuc so they had to be diconected from the network
    I hope this gives you some insight in what precautions and action to take
    Jun 2007
    8
    Oct 2007
    53
    RS-232 on 840-D
    840-D has RS-232 port.
    The safe & easy way is to use DNC Software, from a PC to CNC,
    or use portable, Battery Operated Hand Held Terminal.
    You can see more info at www.digitech-engineers.com
  1. 840D
    By MPTD in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 06-11-2010, 06:23 PM
  2. Transfer Rhino Files 2 BobCAD
    By Hardie in forum BobCad-Cam
    Last Post: 09-04-2009, 09:31 PM
  3. How to Transfer Large Files?
    By adsxy in forum Uncategorised CAD Discussion
    Last Post: 09-13-2008, 12:35 PM
