588,685 active members*
5,927 visitors online*
Thread: Z axis idea
Page 1 of 2 12
Results 1 to 20 of 35
    Mar 2015
    53
    Z axis idea
    Anyone ever built a gantry machine with the z axis rails and ballscrews mounted at the ends of the gantry and the spindle only moving in x along the gantry? (The whole gantry moving in Z)
    I know it doubles up the Z axis parts, but I wondered if it would be more rigid and maybe allow deeper Z?
    Mar 2014
    735
    Re: Z axis idea
    Its been brought up before and then generally dismissed as not a very good idea.
    A couple reasons that come to mind is it would make the moving parts of your Z axis much heavier than necessary. And it would be highly complex in execution to get the same rigidity that one would from a standard gantry with standard Z axis. A 3axis machine would likely require 5 servo/stepper motors instead of 4 or 3.
    35538
    Re: Z axis idea
    I've seen pictures here of a machine like this, but have no idea how to find the thread.
    Apr 2009
    5516
    Re: Z axis idea
    I believe it was pippin's build... There are a few on YouTube. used a rotating nut as well...
    Jan 2008
    1543
    Re: Z axis idea
    Quote Originally Posted by louieatienza View Post
    Different pippin? Cause it wasn't me.
    I've toyed with the idea for a mill though. I would connect the top of the pillars together rigidly.
    Apr 2009
    5516
    Re: Z axis idea
    Quote Originally Posted by pippin88 View Post
    Sorry pippin, mistaken identity. I was close however, it was phife:
    http://www.cnczone.com/forums/diy-cn...ing-nut-2.html
    Mar 2013
    140
    Re: Z axis idea
    Mar 2015
    53
    Re: Z axis idea
    Quote Originally Posted by manofmanyhats View Post
    Very interesting! Thanks.
    That design looks like it only has one rail on each side for the Z axis.
    I think I would have joined the uprights together across the top of the gantry to make it more rigid.
    May 2005
    3920
    Re: Z axis idea
    Ive been thinking of such an apptoach but it is a more intensive build than the normal approach here. My computer broke down so im a bit limited in what i can type here.
    Pros:
    1. Stffier
    2. Fewer moving parts. Im talking controls here on a moving table machine. You would only need a drag chain to the saddle on the gantry beam.
    3. Ends up being a Planer Mill like machine.
    4. Potentially easier to manage dual Y (Gantry) axis saddles.
    Cons
    1. Variable Z clearance
    2. More machining intensive. Access to a machine shop likely required.
    3. More materials required
    4. The need for dual servos on the Z or a mechanical solution between the two lead screws.
    5. Moving the beam up and down is energy intensive this the need to carefull consider drive sizing. The machine may not be ideal for operations dealling with a lot of Z movement.
    In any event that is a start. As for being a good idea that depends upon your usage.
    Mar 2017
    927
    Re: Z axis idea
    I was thinking about this for my machine but I dismissed it because I though it would put too much axial force on the Z-axis rails. Some of that could be addressed by mounting the z rails facing forward on the front of the riser columns but.... ultimately, the goal was to increase rigidity and I concluded that this was better achieved with a fixed gantry.
    Still, a z-axis protruding below the gantry can't be great for stiffness. I am still wondering if I should have made the table move up and down for the Z-axis instead.
    Jul 2018
    6535
    Re: Z axis idea
    Hi Goemon - I know this is old but...How did this work out for you? I'm planning a rising Z axis mill at the moment. I see it as a great solution for increasing rigidity. To add to Wizards list:
    Pros :
    1) Stiffer much much stiffer then a Z axis that hangs way down below the gantry. Plus its relative rigidity to the gantry is constant no matter where it is
    2) No saddle which places the spindle closer to the gantry ie less leverge = stiffer
    Cons
    1) I don't think this matters unless you are doing deep cup shaped objects. You still need a tool long enough to go from part top to part bottom height and this is the beauty of the rising Z the columns can be elephant legs if needed
    2) Not sure why, just as much machining in conventional solutions
    3) No actual less - other then another motor and drive screw all other stuff is the same
    4) No difference to dual axis on Y axis
    5 ) Drive screws generally have heaps of grunt so Z weight is not significant, back driving may happen so put a brake on the motor..
    I think this config could become the std config for high z axis machines. Peter
    Oct 2009
    875
    Re: Z axis idea
    Hi Peter,
    I have one with an active gantry.
    It was my first version with the "Brygga" name. Designed and built in 2015. Using it since then as one of my main cnc's without any problems. It is using V-bearings as at that time linear rails were too expensive.
    It has 14" of z travel and the gantry is fully balanced by springs. It uses Nema23 motors with a chopper board.
    Turned out that the heavy gantry as the z-axis provides for much greater steadiness and accuracy, much more so than a 1/2" thick sheet of aluminum attached to closely spaced linear blocks (which I have on another machine as well).
    I have a bunch of pics and movies if you are interested. I am uploading one for you and will post once it is done.
    I gave up on the design because, as good as it performs, it was too complicated and expensive to manufacture.
    May 2011
    790
    Re: Z axis idea
    Quote Originally Posted by davida1234 View Post
    About a month ago, I was trying to figure out what these types of machines are actually called so I could look up some more examples of them.
    I read your post and was like, oh, active gantry! Now I know!
    There are many large scale rising Z axis machines, but there does not seem to be a common name for it.
    Crap!
    Here is one showing the machine cutting the top of a 14" cube:
    Yeah, that's certainly an advantage. You get better performance when the gantry is low, which is probably most of the time, and can drop your feeds and speeds with it high, doing things like cutting your cube. That's great!
    Your design looks very familiar to this one:
    The main difference looks like you have rack and pinion while they have leadscrews. This design concept may not have caught on with CNC routing, but it looks like it's doing OK with some 3d printing even though it's not super common, while variations of it are.
    The first CNC I built had the same kind of hardened steel guides and v-groove wheels (but the gantry didn't move in the Z direction). Made by PBC Linear. That's funny, because in the background of the video I just linked to there is a PBC linear banner. My experience with their stuff was that some of it was OK, and other stuff was crap.
    It's nice that this subject has come up just as I am in the process of finalizing my latest machine, which I am currently in the process of collecting parts for.
    IMO, Moving gantry in the Z axis and moving bed, there are so many advantages with this kind of design. It's the next standard "mill" design concept that allows for larger travels than a traditional mill does. I don't know why I didn't see this before. No, I'm not actually making a "mill" to cut metal, in what I'm doing now, but the advantages of this design concept have become apparent in my research.
    When you start moving the gantry in two directions, things become more complicated, especially if it's for something like a mill, cutting metal, and you loose a few of your advantages.
    Oct 2009
    875
    Re: Z axis idea
    Here are couple pics and a somewhat lengthy introduction video I made at that time.
    Attachment 443668
    Attachment 443670
    Feb 2005
    829
    Re: Z axis idea
    davida1234 any videos of that machine actually cutting?
    Jul 2018
    6535
    Re: Z axis idea
    Hi David - Can see the love that went into that machine. Unfortunately people won't pay for that stuff but we do move on and its great to hear that its been a successful machine. There are many large scale rising Z axis machines, but there does not seem to be a common name for it. Once it has a commonly recognized name it will become more popular or vis versa. Chicken and egg problem...Maybe a "dual action double moving column with sprinkles" DADMCWS is catchy? Peter
    Active gantry is good too. Lets start a naming contest...
    Oct 2009
    875
    Re: Z axis idea
    Peter, the concept does provide a few advantages.
    One of them is that the spindle can be very close to the gantry beam.
    Then the mass of the gantry as stated.
    The immensely available Z-travel without the problems of tall mounted fixed gantries.
    If you go low, your accuracy goes up.
    If you go high, your accuracy drops.
    On tall mounted fixed gantries, you have low accuracy when high to start with
    and it gets worse if you go low from there.
    The main disadvantage is the necessary weight support system.
    Two pairs of slaved motors for a total of 5-motor system.
    And the mechanical column extensions on the side of the machine.
    Oct 2009
    875
    Re: Z axis idea
    Peter, I actually called it a drawbridge machine. Resembled a drawbridge to me.
    Swedish name for a drawbridge is Brygga, Hence the name.
    Oct 2009
    875
    Re: Z axis idea
    nlancaster, yes I do have a few.
    Here is a 1/8" aluminum in single pass one:
    Oct 2009
    875
    Re: Z axis idea
Page 1 of 2 12
  1. Help With an Y and X axis idea
    By evilr1 in forum MetalWork Discussion
    Last Post: 11-10-2011, 11:38 PM
  2. Simple Z Axis idea
    By zeeway in forum DIY CNC Router Table Machines
    Last Post: 11-01-2009, 02:51 PM
  3. X Axis Idea
    By fahque99 in forum DIY CNC Router Table Machines
    Last Post: 11-23-2008, 01:34 PM
  4. 4th axis idea. Would this work?
    By replicapro in forum Benchtop Machines
    Last Post: 08-22-2006, 01:23 PM
  5. Z axis idea?
    By bearwen in forum DIY CNC Router Table Machines
    Last Post: 03-08-2006, 05:13 AM
