588,380 active members*
4,777 visitors online*
Results 1 to 9 of 9
    May 2007
    250
    Smile How to connect DC servo motor and driver to mach3?
    Dear All,
    I am little puzzled with servo motor and mach3. I know mach3 need pulse and direction to control. Stepping motor,It's not difficult to connect.I know
    For servo motor, I don't know how to connect with mach3.How to link encoder line with mach3? How to set up on mach3 configuration? I am finding some links to describe this on CNC zone but I can not see. Anyone can advise me.
    Hope this help
    Mongkol
    Mar 2005
    306
    you need servo drive have step dir input, connect and setting like stepper, but you need turnning servo.
    b.r
    May 2007
    250
    Unhappy How to link servo driver with BOB and mach3?
    Tivoidethuong,
    Thank you the reply. I know servo driver have step and direction but I don't know how to connect encoder with BOB and mach3.
    How to set up configuration,port and pin on mach3?
    Mongkol
    Dec 2003
    24220
    With Mach, the encoder has to go back to the drive for closing the loop.
    Al.
    Albert E.
    May 2007
    250
    Unhappy
    Al,
    Thank you for the reply.
    You mean that it's not necessary to set up any parameters on port&pin?
    Connect same as stepping motor system? yes or no.
    Mongkol
    Dec 2003
    24220
    The encoder does not go back to the PC just the drive so the step/dir signal is the same as a stepper.
    Al.
    Albert E.
    May 2007
    250
    OK,
    Set up any parameters on port& pin?
    Mongkol
    Aug 2010
    Hi Mongkol, Set-up the pulse / direction signals to the servo drive amplifier the same way you would to a stepper drive. The servo motor feed back from the resolver / encoder will connect into the servo drive amplifier. The servo drive amplifier will output the same amount of pulses as the number of pulses it receives from mach 3.... not always strictly true because the number of pulses can be divided or multiplied by the servo amplifier.
    Oct 2012
    6
    Hi Mongkol,
    Now I am trying to use servo motor on my home built cnc, but i have no idea how to hook it up with BOB. Pls help.. Thanks.
  1. Replies: 4
    Last Post: 09-08-2011, 11:41 PM
  2. 6 leads stepper motor connect to TB6560AHQ stepper driver board
    By wf1318 in forum Stepper Motors / Drives
    Last Post: 07-25-2010, 08:19 AM
  3. old DC PM servo motor driver
    By visky in forum Servo Motors / Drives
    Last Post: 11-21-2008, 04:21 PM
  4. Connect 200V servo motor to 400V drive
    By interflexo in forum Servo Motors / Drives
    Last Post: 04-15-2008, 07:34 PM
  5. Replies: 2
    Last Post: 03-29-2008, 03:43 PM
