587,998 active members*
1,889 visitors online*
Results 1 to 17 of 17
    May 2016
    32
    The SeCret Buttons...........
    Hey,
    I got a masterwood and what no manual says is that if u press M...T.....u come in the screen where u can test youre in and outputs. if u press D in the main u get to see the delivery date.....The manual clearly keeps on saying is that the serial connection is one way only!!! and when u look in the langauge file it has translations ( yes the have ) for RX and TX so this is making me really wonder what else i can do with the machine....lno way i could get it dripfeeding today while the program itself does when u are transmitting from the pc.
    so who knows any dirty secrets bout my machine or your own or neighbours cnc?
    Thanx
    Jun 2010
    19
    Re: The SeCret Buttons...........
    Hi Bob, my name is Pascual, from Spain, I have an atlas MASTERWOOD L, came with control CN10 and soft mw309. I bought it recently in a auction, and comes without technical documentation or instruction manual.
    I could find an instruction manual of a MASTERWOOD project, with control cnc10, but does not explain how to change the working language of the machine. This machine is in Dutch. this is nothing comfortable. You'd know explain how language is changed?
    May 2016
    32
    if u are in the mainscreen u press P from parameter, then u type PARM as a password, then u scroll trough the next screen till u get to "GENERIC PARAM.2" att the bottom there is a parameter called LINGUA it the last one, it says 4,
    then u press 1 for italian 2 for englisch 3 for german 4 for dutch butt its different at any machine, and iff that wont work we screw out your cn10 and we switcht it for my cn7
    Jun 2010
    19
    thank you very much, I'm running to my other store to connect the MASTERWOOD ATLAS to see if it works these instructions, I have all day watching various threads of this brand of machines in different forums.
    I'm looking for instructions for the machine, electrical wiring and compressed air, postprocessors for MASTERWOOD atlas, or for MASTERWOOD project, with control software CN10 with mw309.
    ....i goooo
    May 2016
    32
    lett me know if it worked
    yw
    Jun 2010
    19
    good morning, yes, I can access the hidden menu of the machine, and move from screen to screen, but I do not see the line where I can change the language.
    attached screenshots of the different menus that appear me.
    apparently the machine language is Dutch.
    I've been testing different combinations of keyboard, and I discovered a couple of menus more.
    in the main menu, if you press M and write as PARM password, you can see different parameters settings of the axes of the machine.Attachment 322420Attachment 322422Attachment 322424Attachment 322426Click image for larger version.
ID:	322428Click image for larger version.
ID:	322430Click image for larger version.
    35538
    Looks like an error in the code? Does it say Line 0, it's hard to see?
    There should be a list of error codes that will tell you what that error number may mean.
    Jun 2010
    19
    .thanks for your quick response. i send more pixel photo:Attachment 327856Attachment 327858Attachment 327860
    Jun 2010
    19
    hello all, the last error i had in my machine that caused by a cone inserted into the mandrel, while I try to reset from home to start the machine.
    this is not allowed.
    It is a beginner's mistake, but I do not have any documentation of the machine, and do not know the boot process of the machine.
    I'm in a long process of trial and error.
    Jun 2010
    19
    last night i was practicing loading old programs the machine to try to cut something.
    I found some internal promama that contains no errors tools, limits, etc.
    Now the machine starts the machining process and prepares to load a tool from the charger.
    the machine goes through a meter and when it stops to pick up a tool, gives an error of delay time,
    2.1.1557.something on a cylinder of compressed air involved in the tool change ... or mandrel. I will review the logic inputs of the machine to find out that the electronic circuit is involved in this mistake ... and from there will locate the sensor connected to that input.
    Attachment 328342you know which one is the ratio of the number of entry that appears on the screen with your equivalence between electronic control cabinet cards?Attachment 328344
    Jun 2010
    19
    error 2.1.1557. one of rear bumpers used as guides to put doors to machine, not down to the bottom, and the sensor was not as correct operation. Clean it and oil, work ok.
    after that, the error 2.1.1020. it was very simple.
    you can not do reset if you have a tool set on the mandrel.
    manually remove the tool and put it in the changer.
    Anther error, This has been a headache, 2.1.1536 (pistone c.u. 1 su) c.u. = cambio utensile : the air pressure switch in tube gives pressure to clamp the mandrel, is N.C. normal closet, I not work fast enough. I change it and the error does not appears.
    at this time the machine tool changes and working properly. ufff !!! jjejeje
    I can work with internal sequences that bring the machine. They are machined from the old owners of the machine.
    now I have to learn to introducing vectors into the machining program to program machining with the right tools.
    I can you say that vector format are correct to do this?
    or programs have incorporated postprocessors are available for this cpu (CN10 With mw309))
    thanks in advance
    Jun 2010
    19
    last night, I put up an old sequence that was in the memory of the machine.
    this is the result, ejej
    https://youtu.be/HkUkI-Q6_Ec
  1. What Is the Secret To Drilling A Straight Hole?
    By SCzEngrgGroup in forum Novakon
    Last Post: 10-28-2021, 03:15 PM
  2. Secret to using mdf on a cnc router?
    By johngalt47 in forum WoodWorking Topics
    Last Post: 04-06-2014, 07:36 PM
  3. Replies: 39
    Last Post: 09-14-2010, 07:24 AM
  4. Secret to plastic?
    By Crawler374 in forum DIY CNC Router Table Machines
    Last Post: 01-25-2010, 02:21 AM
