588,510 active members*
5,488 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Machine Check: Failed.....Executive Load: Failed
Results 1 to 2 of 2
    Aug 2014
    I have A Bridgeport Discovery 308. I think it is a 1991. I have been running it for about three years, having very few issues. A couple of days ago it was running fine, but the air temperature was getting warm and I thought it was a good idea to shut down. Went to do a tool change to clear the spindle, and the moniter screen "froze", which it has done before. This is usually taken care of by shutting down and then starting up again, that has worked each time before to correct a frozen screen. This time instead of the machine check...ok and then going to the screen with the enable button, I got Machine Check: failed...Executive Load: failed..error code -1 C:/_.
    Any thoughts, input, or ideas that will help me get past this would be greatly appreciated. Thank you.
    Mar 2007
    49
    Re: Machine Check: Failed.....Executive Load: Failed
    Try reseating the BMDC card in its expansion slot.
    Brian
  1. Something's failed - but I can't work out what!!! :(
    By sideways in forum Stepper Motors / Drives
    Last Post: 11-29-2013, 03:06 PM
  2. Failed to Load PostProcessor
    By Stupidav in forum ArtCam Pro
    Last Post: 12-22-2011, 11:22 PM
  3. 971 Failed to load
    By GPdriver in forum Haas Mills
    Last Post: 10-11-2011, 09:14 PM
  4. Failed transformers?
    By Jetlag in forum CNC Machine Related Electronics
    Last Post: 09-09-2005, 08:50 PM
  5. V2XT - machine check failed
    By zcases in forum Bridgeport / Hardinge Mills
    Last Post: 06-07-2005, 08:16 PM
