587,524 active members*
3,360 visitors online*
Results 1 to 3 of 3
    Jan 2007
    6
    Exclamation Galil motion control MBA-6-60
    Hi
    I want to test a galil motion control driver MBA-6-60 and need to connect it to an old parvalux BL42 brushless motor but got no idea what wires to connect where. On the galil where do I connect the pots etc. The motor has 5 wires red,blue, green, white, black for hall sensors and red black and white for the motor. Would appreciate any help.
    Dec 2003
    24220
    The Galil drive is basically a re-labeled A-M-C B12A6 drive.
    the three motor power leads go to Motor A B C, power is 20-60vdc.
    I imagine the motor halls are red blk power, and blue, green, white would be the halls?
    I do not have any info on that motor, the hall supply can be taken from the P1-10 P1-11.
    You need to supply a ±10vdc signal to the P1-4 P1-5 to test, a battery will work.
    Initially connect the halls only, and turn the motor over by hand the ready light should stay green, if it changes to red then you have the sequence wrong.
    If after connecting power you get strange control, then you may have to try the 6 combinations of the 3 power leads.
    Go to the A-M-C site for the technical info.
    Al.
    Al.
    Attached Thumbnails Attached Thumbnails catmba6_60.pdf
    Albert E.
    Jan 2007
    6
    Thanks Al
  1. galil motion control with visual Basic 6.0 activeX
    By servomec04 in forum Open Source Controller Boards
    Last Post: 03-05-2012, 03:42 PM
  2. cnc professional- galil motion card dmc2152
    By japco43 in forum CamSoft Products
    Last Post: 11-08-2011, 02:10 AM
  3. galil motion control active X toolkit
    By servomec04 in forum CNC Machine Related Electronics
    Last Post: 05-24-2011, 04:19 AM
  4. Galil motion controller question
    By REVCAM_Bob in forum CNC Machine Related Electronics
    Last Post: 07-22-2007, 10:24 PM
