588,658 active members*
4,791 visitors online*
Results 1 to 9 of 9
    Jun 2009
    3
    HP Draftmaster II driver
    I have a perfectly good HP Draftmaster II pen plotter. It will produce good drawings on "E" sized paper (36x42 in.). I haven't used it for a few years and now with a new PC loaded with XP software I need a driver for it. A driver is not resident in the XP package and HP tech service cannot help me. Can anyone help me with this problem. It seems a pitty to toss it for want of a driver.
    billybird
    Jan 2009
    237
    Draftmaster Driver
    There is the application "WinLine" that has the driver for the HP printer/plotters.
    A fee is required. but I think there is a demo.
    CakG
    Jan 2009
    237
    OH!
    The application "SignGO" has drivers for just about every device.
    Check it out, There is a demo there for sure.
    If it's a HP-GL2 driver ( very likely) There are many applications that have such drivers
    CorelDraw? Eagle PCB software, or you can get a postscript converter PSTOEDIT etc.
    Search the net.
    CalG
    Jun 2007
    6
    Signgo has no driver for draftmaster and even when you can get one you can't add it because you can only choose of their own list
    Jan 2009
    237
    The HP 7596A uses the HP-GL language.
    No "special drivers" are required. Only programs that output HP-GL. A search on "HP-GL" will find many solutions. Recent editions of Windoz makes it troublesome and requires conversion from some other file type to the required HP-GL .
    Signgo has MANY HP-GL compatable settings. I have used it on my HP 7550
    Presently, Under Linux, I use "Inkscape" and a conversion application.
    Good luck! Keep trying
    Jan 2009
    237
    http://forum.uscutter.com/index.php?board=41.0
    An interesting link regarding plotters. cutters, and software
    7
    Plotter Driver
    Have you tried AutoDesk's DWG TrueView Software?? Its a viewer/markup program that has a lot of plotter drivers including some for HPGL plotters like the 7475A and one for the Draftmaster 2 HPGL.
    Its free and comes in versions for WinXP 32/64 bit and Win7 32/64 bit. I don't work for them, I just use the software for drawing review, but I did notice the plotter setup tab included HP plotters. I believe it handles dwg and dfx files but there may be some font incompatibilites.
    AZSkies2002
    Jan 2009
    237
    AZSkies
    Thank you for that link.
    A perfect HP 7550A output file at the touch of a mouse button.
    Well, I did need to set up a "save to file" location.
    Progress with an old machine!
    Should work just fine with the OP application.
    Best regards
    CalG
  1. Best MOSFET Driver and MOSFET choice for an H-Bridge Stepper Driver?
    By joprinz in forum CNC Machine Related Electronics
    Last Post: 04-28-2011, 09:57 AM
  2. driver
    By MR MOTION in forum Open Source Controller Boards
    Last Post: 04-07-2009, 11:52 AM
  3. single axis driver and a b.o.b.,or multi-axis driver board
    By .xXACEXx. in forum Stepper Motors / Drives
    Last Post: 07-03-2007, 05:13 AM
  4. STEPPER DRIVER FAQ {Stepper/driver amp per phase match.
    By huios in forum Stepper Motors / Drives
    Last Post: 08-27-2006, 02:43 PM
  5. Which driver to use? There are so many!
    By cn00728 in forum Stepper Motors / Drives
    Last Post: 01-01-2005, 04:41 AM
