588,044 active members*
3,394 visitors online*
IndustryArena Forum > MetalWorking > Mass finishing equipment/media/strategies > Vibratory Finisher For Polishing Aluminum
Results 1 to 20 of 24
    Feb 2006
    7063
    I have been going NUTS trying to find out how to use a vibratory finisher to polish aluminum (6061) parts after machining. I first contacted Raytech, who advised me on which machine to buy, and which media. I bought the machine, and $100 worth of media. The machine was about 3 sizes too small! The roughing media, green pyramids, worked well. The polishing meda, walnut shells and rouge did absolutely doodle-e-squat. So, back everything went. I then bought a Vibrahone Model C. MUCH, MUCH, MUCH better machine. I was told to use the same green pyramids, and then ceramic cylinders, with pumice. The ceramic and pumice, like the walnut shells and rouge before, did NOTHING!
    What is the secret recipe, and why does nobody seem to be able to tell me how to do such a simple thing?
    Regards,
    Ray L.
    Jul 2006
    297
    i have been in search of the same info,the rep we are dealing with promised the moon and when the parts got back they were exactly the way i did not want them,then they start talking about bigger machine more money yada yada yada.
    i read on a post somewhere that someone run parts ofr 7 days in the walnut rouge deal and get perfectly chrome looking parts.
    thats a long time
    2007 Haas TMP-1 Microscribe MX-5 Mastercam X4 Mill Level 3 Surfaces,Solids Seagate 2 tb hard drive AMD 64x2 8gig ram windows ultimate 7 64bit Geoforce 8800 GTX
    Jul 2006
    297
    just checked out the model you purchased,looks like a small benchtop model,may take longer to achieve same results than a floor type model.
    keep us posted on your findings
    Aug 2005
    24
    I've had no luck with this - running a burr-king model 33 with all kinds of media - seems like if you overload the tumblers, the parts make contact occasionally causing marks... same deal with the suppliers - promise the world.
    Anyone know about chemical-polish before bright-anodizing?
    Oct 2008
    9
    Call Dan Lord at C&M Topline in CA...send him samples and he will develop your process. I have only bought media from him for our little Burr King, but they have a full line of product, and are significantly less money than anyone else. Finding the right combination of products is not easy with the numerous choices of media and juice, so rely on Dan, but support him with your purchase. In a previous life, we had one of their 3 cu/ft tumblers...ran daily for at least a half a dozen years with ZERO problems - I am not affiliated, just a satisfied customer.
    I haven't run any aluminum (only brass) in a polishing application, but everyone I have talked to says hours to polish with walnut shells, like 10-12 hours, but they look like chrome when they're done.
    Steve
    Feb 2006
    7063
    Today I spoke with the owner of Tagit, which manufactures the VibraHone machine I have. I am sending him some of my parts, and he is going to develop a process for me. He feels I do have the correct media, but apparently the amount of water you use is very critical, and sometimes some minor additives, like soap, are required. He has promised to get back to me in under a week with the "recipe" for doing my specific parts. He certainly seemed a lot more knowledgable than anyone I've spoken with so far.
    I'll report back when I hear back from him.
    Regads,
    Ray L.
    Feb 2006
    7063
    The C&M Topline website has more useful information than any other site I've come across. I've e-mailed them to get their advice as well. They have some good information on how to deburr and polish 6061, so it should be an easy question for them to answer. Unfortunately, I've already figured out I was sold (again!) the wrong media. The ceramic media I have is 1/8" slant-cut cylinders, and the C&M site recommends balls for aluminum. 1/8" is also too smal for my parts, which have several holes and a long 1/8" wide by 1/8" deep groove, which ends up with the littel cylinders wedged in very tightly. They're VERY difficult to remove.
    This has turned into a VERY expensive, VERY time-consuming problem....
    Regards,
    Ray L.
    Jul 2006
    297
    Himy,the steel or ceramic balls do not polish like you are looking for they provide a luster but the biggest issue with the balls is they leave a peened finish kind of like a microscopic golf ball dimple pattern on the surface.
    i personally didnt like it myself.
    as mentioned the 10-12 hour walnut and rouge solution seems to provide the near chrome look we are after,the other types of media are use for deburring and light cutting.
    i am looking into building my own vibratory finisher and anyone who has any links pleas let me know.
    thanks
    tim
    Jun 2008
    475
    Quote Originally Posted by HimyKabibble View Post
    Regards,
    Ray L.
    Ray,
    Did you ever get this figured out and if so, how are your results ?
    Dec 2007
    19
    Hey Guys!
    I know the secret for success... ... I have tried a lot of stuff and have figured it out... first of all you must have a VIBRATORY tumbler... they are way more effective then an ordinary tumbler, maybe 10 - 25 times faster.
    The media you should start to use is a plastic media... mentioned above as green pyramids... There are many types of plastic media depending on how hard you want to sand the part. I first use a plastic media formed as pyramids for very rough sanding of the part, and later another type of plastic media for nicer finish of the part. The final media to use is walnut or corn cob. Walnut does not give as good finish as corn cob, but almost... but if you want that true mirror shine you should use corn cob. Also what is very important is that the walnut or corn cob is treated with a polishing liquid/creme. One of you tried walnut but couldn't see any results... maybe you didn't have any polishing liquid/creme with the walnut media? You must have that... you can't run it with untreated walnut, if you do, you won't see any differense at all.
    And that's it... you can't fail if you follow that instruction...
    Two other things that I have heard, but what I think don't matter as much is the water part and soap part.
    Some say that you must have water that is circulating... I say that it's not that important... okey that you need water, but you don't need circulation as much as thoose people claim.
    Same is with the soap thing... okey that you will get a better finish if using som special soap, but the difference is not that great so you could skip this step.
    Aug 2007
    147
    Walnut shells with rouge should work very well in a vibratory tumbler after 12-24 hours.
    A decent finish off the machine certainly helps. How are your parts looking after tumbling with the plastic pyramids?
    A brief blog entry on tumbling...
    Jul 2006
    142
    I have been polishing all my parts prior to anodizing for about 2 years now. The key is to have the correct polishing media!!!!
    I use a product from C&S sales out of Wisconsin, and trust me, you get chrome looking parts after about 8-12 hours in a Vibratory tumbler, that is after an hour or so in the plastic media to remove machine marks.
    Now my problem is a have a bottle neck at the polishing , with 2 of the bench top Tumblers I have, time to step up to a larger machine.
    Anybody have any experiance with these type of machines? They are a Chinese import, found them on E-bay, auction number.
    180425035398
    Don't have the funds for a Sweco,
    Take care,
    Smitty
    May 2007
    100
    Smitty, if you buy this machine, please post your results.
    Thanks,
    Joel
    Jul 2006
    142
    I have 2 of the Tumbers that Glacern has, very nice machines, just on the SMALL side, they run for over 6 months 24-7!!!
    Have traded a few E-mails with the guy on E-bay, seems like an ok guy. REAL close to pulling the trigger on it!!!
    Will keep ya all posted,
    Smitty
    Jun 2005
    1015
    i was able to achieve the same finish as on those chess peices in my harbor freight bowl tumbler. i used the little 5lb one and later bought the bigger one. its a three step process. 1 use the green triangles to get a matte finish, this took about 6-8 hours to remove all the tooling marks from the parts. then i followed up with coarse walnut shells dry. no additional rouge or polishing compound. this got them to a brighter more uniform finish. then i followed up with walnut shells and added wenol metal polish to media. the final polishing took about 16 hours to get them really bright and shiny. granted this is not the best approach for production, but just meant to illustrate that it can be done with cheaper non professional equipment. total investment was about $100 including the tumbler with warranty, the green triangle media, and the walnut shells, all purchased at harbor freight. the wenol cost me about $10 and was purchased at an autoparts store. i suspect that really any mag wheel polish will work instead of the wenol
    Jul 2006
    142
    Quote Originally Posted by JHCHOPPERS View Post
    Thanks,
    Joel
    Spoke with the guy selling this morning. My main concern, will the machine do WHAT I need it to do... and that is POLISH using the media I have now, which by the way works simply awesome!!!
    Anyhow, and this is where I was speechless, he offered to send the machine to me, and try it out for a couple weeks. If I did not like the results, I can send the machine back, and just pay the freight.
    Are there really people like that anymore??!!! A mans word is his BOND!
    So I took him up on his offer, if the tumbler is anything like the seller, I think I will be getting a fine machine.
    Will keep ya ll posted next week.
    Also, for those that are looking for an awesome media, check out c&s sales, ask for #20 highlite, nothing I have ever tried comes even close.
    Take care,
    Smitty
    May 2007
    100
    Very nice.... Please take pictures and post your results on that Big Bad Boy
    Joel
    Feb 2005
    753
    Okay reading some of your posts it seems I need some type of polishing compound.
    I have an ultra vibe 45.. I am trying to polish. I have the walnut shells.
    Feb 2005
    753
    What is rouge?
  1. Home Brewed vibratory finisher
    By Unabiker in forum Mass finishing equipment/media/strategies
    Last Post: 05-23-2014, 01:06 PM
  2. Vibratory Polishing Washers...?
    By tof1 in forum Mass finishing equipment/media/strategies
    Last Post: 07-20-2008, 12:48 AM
  3. Recommended vibratory media for Aluminum
    By SRT Mike in forum Mass finishing equipment/media/strategies
    Last Post: 03-30-2007, 01:46 PM
  4. Vibratory Finisher for smaller Apps.
    By behemoth in forum Mass finishing equipment/media/strategies
    Last Post: 12-16-2005, 01:30 PM
  5. Vibratory polishers and aluminum
    By jkeyser14 in forum MetalWork Discussion
    Last Post: 05-16-2005, 09:11 PM
