588,107 active members*
5,765 visitors online*
Page 1 of 6 123
Results 1 to 20 of 109
    Sep 2009
    153
    MD001 cnc conversion
    I purchased:MD001 8 years ago and now just getting to work on it. I retired and moved to Texas. Built my new shop and finally finished it. I needed to build my cnc router so I could machine my parts. I’m really excited to get started on this project. Thanks for your feedback
    Sep 2009
    153
    Re: MD001 cnc conversion
    I’m going to cut dovetails off so I can put linear bearing on to replace dove tails. I bought linear bearing on eBay and I think I can use my cnc router to cut dovetails off. I’m going to try 4 flute carbide end mill at 3000rpm and 17im .0625 depth of cut. I’ve never cut cast iron on my router but that looks like the only option at this time.
    Sep 2009
    153
    Added bolts to the sides to add support for rail bolts.
    Sep 2009
    153
    Fired up router full expecting to break my bit but cut both table and column with same bit. Took little over 6 hrs for table and 4 hrs for column.
    Sep 2009
    153
    Finished cutting now I need to mount linear rails. Ordered bolts and waiting for them to get here.
    Sep 2009
    153
    I
    Sep 2009
    153
    I originally purchased DMM servo’s for this build but digging through my servo pile I think I’m going to use these instead. I have not looked into wiring for encoders to drives I have but I’ll need to research wiring I also originally purchased a Chinese BT30 ATC spindle when I started this project.
    Nov 2013
    4599
    how many cars do you have on each rail? The picture shows just one. Two cars per rail is the norm and very much more stable.
    Craig
    Sep 2009
    153
    The cars are 6.875” long. When I originally purchase these on eBay I was going to put 2 per side till I got them and saw how big they were.
    Sep 2009
    153
    I was going to make my ATC air cylinder but digging thru my junk cylinders a found 5 Fabco-Air cylinders. This one has 1" stroke, but I think it is pull not push. If anyone has information about this cylinder, please let me know. Thanks
    Sep 2009
    153
    My spindle servo is rated at 10.5 Nm and 3000 rpm’s. If I drive it 1:2 to get 6000 rpm’s will that kill my torque. I would like to not have to manually change gear ratios if I can get away with it.
    Sep 2009
    153
    Took Fabco stacked cylinder apart and it was pulling cylinder. I wanted to rebuild it anyway. If you flip everything over, you can reverse force direction. Fabco-Air Inc. has drawings and chart for power. This is a 3" piston that has little over 2,000 lbs. force at 100 psi. with 1" stroke. I like the fact that you don't have to run air lines to each individual cylinder. From what I see I think that's going to work.
    Nov 2013
    4599
    is the spindle a repurposed AC servo or is it a genuine spindle motor?
    My Delta servos are rated to 3000rpm but have a maximum of 5000rpm. They generate rated torque at rated speed, but at higher speeds the torque linearly diminishes as the speed increases.
    The is a common property of AC servos and is called 'Field Weakening'.
    You may have noticed that AC motors intended for spindle service are actually very much like AC servos, they have an encoder and a matching drive. They will often have a rated speed of 2000rpm and a rated torque
    of 20Nm........but they can still run at 8000rpm??? How is this possible? It is due to field weakening.
    An AC servo is an example of a Field Oriented Controlled motor. It has an encoder to accurately monitor the angular position of the rotor. The three phase currents that are supplied to the motor are precisely calculated
    to produce a combined magnetic field at 90 degrees to the rotor, thereby getting the maximum torque for the least current. A few microseconds later and the rotor has turned a little, the applied currents are recalculated
    so that they remain 90 degrees to the rotor. Very clever, and describes why servos have such good torque production for their size.
    One property of a motor is called the 'Back EMF Constant'. As the motor spins it generates a back voltage. So at a given or max speed, the back EMF is nearly equal to the applied voltage and therefore the motor can
    go no faster. The strength of the magnetic field of the rotor is very significant in determining what the back EMF is and therefore determines the max speed.
    One of the things that you can do with Field oriented control is to provide the three phase currents such that there is a component of the net magnetic field that is 90 degrees to the rotor and produces torque,
    but also supply some current that opposes the magnetic field of the rotor. This has the effect of reducing the magnetism of the rotor (field weakening) and thereby reduces the Back EMF and allows the motor to go faster
    for a given input voltage. Very clever....but its not a free lunch, the torque output is reduced.
    Lets say our spindle motor from above has 20Nm torque at 2000rpm. At 8000 rpm the torque is 20 x (2000/8000) = 5Nm This is how a spindle motor can produce really high torques at slow speeds, it is when all said
    and done a low speed high torque motor, but because of the wrinkle called field weakening can still spin really fast as well. The best of both worlds. Servos use the same principle but usually less dramatically.
    Craig
    Sep 2009
    153
    This is the servo I'm planning on using. I hope this helps.
    Greg
    Nov 2013
    4599
    without knowing what servo drive you have I would guess it to be similar to my Delta servos, ie rated to 3000rpm but have a modest overspeed region using
    field weakening. It might be possible to push that servo to 4000rpm, 4500rpm, or maybe even 5000rpm.
    Craig
    Nov 2013
    4599
    even if you do use field weakening to extend the speed envelope of a motor you still suffer exactly the same torque reduction as you would with a gearbox or belt increase.
    Lets say a servo has 10.5Nm at 3000rpm. Assuming you can use field weakening then at 6000rpm you'd have 10.5 x ( 3000/6000)=5.25Nm.
    If you used a gearbox (with no losses) then 1:2 speed increase will result in a 2:1 torque reduction ie 5.25Nm.
    The only advantage of field weakening is that it avoids for the need of a gearbox, the losses associated with the gearbox and the drag of having to changes gears all the time.
    Craig
    Sep 2009
    153
    This is the drive I'm going to use.
    Thanks Greg
    Nov 2013
    4599
    you need to get the set-up and tuning software for this drive.
    On page 79 of the manual it shows the dialogue to set the motor, including the max rpm. Note also that you can nominate a specific matching servo from a database and the database will populate the motor parameters.
    I have an Allen Bradley servo that does the same thing. The only problem is that if the max speed is set by the database you cannot arbitrarily set it higher. With my Allen Bradley servo for instance that
    means that I cannot run it faster than rated speed because the software does not allow it. Maybe Kollmorgen have done it differently. It would be nice to extend the speed range of that servo, but it is possible that
    the software and/or drive do not permit field weakening. Get the software and try it out.
    Craig
    Sep 2009
    153
    Thanks for the advice, Craig. After looking at options going with single drive 1:2 belt is going to cut my torque in half all the time vs twin drive belt which will only cut my torque when in high spindle speed. The field option is intriguing but looking thru manual I don't think that is an option. It looks like the drive needs a large resistor to handle excess voltage generated. I don't know how much I will need to use high speed spindle settings. So just using 3,000 rpm might be the option. My router goes to 22,000 so I can possibly use it if need be. I've cut stainless and metal on it. But if I do a twin belt, I'm leaning toward air shifting 2 speeds, so I don't have to adjust belts. I find if you have to spend time setting up machines you tend to find a way around it. Thanks again for clearing that up Craig you have excellent knowledge of subject.
    Nov 2013
    4599
    The braking resistor has absolutely nothing to do with it.
    Craig
Page 1 of 6 123
  1. MTW MD001 CNC Conversion
    By vertcnc in forum Benchtop Machines
    Last Post: 02-09-2018, 01:31 AM
  2. Dave's MD001 CNC conversion
    By dave111 in forum Benchtop Machines
    Last Post: 03-13-2015, 04:30 AM
  3. Austin's MD001 / IH clone CNC conversion build
    By BrownDesert in forum Benchtop Machines
    Last Post: 06-24-2014, 01:22 PM
  4. New MTW MD001
    By Redgoatfab in forum Benchtop Machines
    Last Post: 03-02-2012, 04:36 PM
  5. MD001 gibs
    By yooooda in forum Benchtop Machines
    Last Post: 03-02-2012, 05:48 AM
